B16 rods in JDM d15b?
Old May 17, 2006 | 01:40 AM
Boostage's Avatar
Default B16 rods in JDM d15b?
I have a set of Eagle forged b16 rods. I just realised that d15b's have 134mm rods. and my eagles are 134.36mm. would this work? if so what bearings would I use?
Old May 17, 2006 | 05:00 AM
schardbody's Avatar
d15b uses 137mm rods not 134mm.
Old May 17, 2006 | 12:03 PM
Boostage's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">d15b uses 137mm rods not 134mm.</TD></TR></TABLE>
You are right but look at this chart.
http://www.knology.net/~jediklc/specs.htm
It says basically saying the deck height of the jdm d15b is the same as the D15B7 which does use a 134mm rod. I had all this info before posting, but I didnt want to make the question too confusing. but still what bearings would I use and what would the c/r be with a y8 head gasket with vitara pistons?
Old May 17, 2006 | 01:04 PM
schardbody's Avatar
well, what block, crank, head, pistons, etc are you using, or planning to use. if you want PM me the setup you got in mind, or the parts you got and compression ratio you are looking for and when i get home later i can help a little more, i dont really have time at work.
Old May 17, 2006 | 01:17 PM
shanepa2001's Avatar
Default Re: B16 rods in JDM d15b? (Boostage)
hey man i got the same engine and love it to death but am F*&$$@* sick of not being able to find internals to swap with it. plllleeeaaasseee keep this thread goin and see what happens because i want to replace the pistons and rods but cant get any info on them thats solid enough to buy a 500 dollar set of pisitons on...any one wit any info in this please post it
Old May 17, 2006 | 01:19 PM
schardbody's Avatar
they are available, just gotta know how to do math. let me get home and both of you PM me the engines you're using, and what you want out of it, and i can find internals for whatever CR you want, N/A or boosted. just PM me.
cameron_bailey
Mar 15, 2013 05:54 AM
mtownsi
Mar 30, 2007 03:17 AM
Ak_ef9
Oct 2, 2006 06:53 PM
Mr. Em1
Feb 12, 2006 06:58 AM
I wanna be Steve!
Jun 2, 2003 07:21 PM
