NEED SOME HELP, DOING TRANNY SWAP!!!!!!! ASAP!!!!
hi there, i need some help regarding a tranny swap from auto to manual, first off is the ecu, will i need a manual ecu? second axles can i save some of mine or just buy new ones but for manual.
Modified by jdmCD7accord at 5:30 PM 5/17/2006
First off you need to turn the caps off and you'll get some responses. Second you'll need to get a manual ecu, and I believe new axles since the manual and auto are different but someone hopefully chime in and give you some more info.
Try editing your post using <U>UPPER</U> and <U>lower </U>and you may get some more help.
