Window Problem!
Hello,
Well i have a problem with my window. its not powered so i have to wind it up and down, but its not that easy. its like the actual window gets off line and i have to pull it up then keep winding it, then pull it again. could i fix this my self or just take it to a shop? if im not explaing that well i can maybe get pictures!
i was wondering if you guys go show me how to remove the panels and stuff. like do i just take a flathead and start prying everything off? plz help! my dad is making me take it to a shop but i dont want to spend any money on something i could probably fix... unless its a part.
its easy, if u have crank up windows, u have to take out the roll up handle, then unscrew the door handle molding and there are screws where the speaker is. and another screw where u pull to close the door. after u take these screws out, the door panel is held on buy clip like things that should just pop out the panel by a lil bit of force.
It's sorta hard to explain. I was at a thrift store and I was lucky enough to find a Haynes manual that explains it. I got it for 50 cents. It's pretty much the same for manual and automatic windows. Maybe I can scan the pages and email'em to you.
mika
Jan 9, 2005 04:42 PM
