help
Old May 16, 2006 | 08:18 PM
93cavRS's Avatar
Default help
k im fairly new here and dunt have the time to research much so, im wondering can ne body help me. i wanna swap a b18a outta 90-93 teg and im wondering what will i need to do, to this swap rite, everything and anything that i need to no plz tell me.
thx
Old May 16, 2006 | 08:34 PM
thevtecnician's Avatar
Default Re: help (93cavRS)
I'm assuming you have an ef honda. But what year and model iz it?
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: help (thevtecnician)
You don't have time to research but time for a swap.
Old May 16, 2006 | 08:47 PM
93cavRS's Avatar
Default Re: help (***-assin)
ok i want to research it as much as poss but i would like some help, yes i have a 91 ef hb and im really unsure bout what motor is in it now ill check morrow but if i can get links and whatnot about the swap thats fine ill read em...jus really looking for help
thx
Old May 16, 2006 | 09:00 PM
Si? Dx? Standard?
Old May 16, 2006 | 09:03 PM
93cavRS's Avatar
not an si, std tranny...sorry for all the screw ups lol
Old May 16, 2006 | 09:20 PM
If you have a standard tranny I'm gonna assume you have a base model hatch.
Your gonna have to first convert your car from DPFI ( dual point fuel injection) to MPFI(multipoint fuel injection). The b18a (motor from 90-93 teg) is a mpfi engine.
Your gonna need b-series swap mounts,and b-series swap shift linkage. If your car has a standard tranny it must have the standard hubs which will have to be swapped out for dx or si hubs. The b-series axles that you have to use won't fit into the base model hubs.
Also, you need at least a civic si ecu. It would be best to just use the b18a ecu.
Also, some engine mounts require you to cut a notch into front crossmember. I had a ls/vtec combo in my 88 hatch and I used placeracing mounts and I needed the extra room for the header. Not all mounts require you to cut anything.
Last thing I can remember is that you have to dent the framerail a bit where your stock alternator is because the b-series alternator sticks out further.
Use the 90-93 teg axles.
Any q's?
Old May 17, 2006 | 07:40 PM
93cavRS's Avatar
ok thx for all that, im jus gunna buy a junkd teg that has a gd motor and tranny so im guessing ill have all the axels and **** there. so how do i covert to mpfi?
Old May 18, 2006 | 07:54 PM
93cavRS's Avatar
ne one?
mrEFman
10
Jan 20, 2007 06:01 PM
b-16delslow
Jul 11, 2006 06:43 PM
