auto to manual swap done - low redline? ecu??
Old May 16, 2006 | 06:40 PM
hb_guy's Avatar
Default auto to manual swap done - low redline? ecu??
i have a 91 civic ex and i just converted to 5 speed.
but i am still running the ps9 ecu.
my redline is like at 5-6k. it just like loses power like it was losing fuel.
should i go with a pm6? has anyone had this prob before?
please help, wanna drive my car - plus it is 10.5:1 comp
Old May 16, 2006 | 07:10 PM
SD_Lurker's Avatar
HT White Ops
Default Re: auto to manual swap done - low redline? ecu?? (hb_guy)
You can not use an automatic ECU. The car will run like ****.
Old May 16, 2006 | 08:58 PM
hb_guy's Avatar
Default Re: auto to manual swap done - low redline? ecu?? (nicks_jdmstyle_ef9)
so should i modify it or get a pm6? lemme know someone!!!!
Old May 16, 2006 | 09:04 PM
thevtecnician's Avatar
You can't use an automatic ecu on a 5 speed period. You need a new ecu. Pm6 would do. But if you say you 10.5:1 compression you might want to chip it to suit whatever your setup is.
Old May 17, 2006 | 04:39 AM
hb_guy's Avatar
Default Re: auto to manual swap done - low redline? ecu?? (thevtecnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">You can't use an automatic ecu on a 5 speed period. You need a new ecu. Pm6 would do. But if you say you 10.5:1 compression you might want to chip it to suit whatever your setup is.</TD></TR></TABLE>
then what is the purpose of modifying an ecu if u can't/shouldn't use it??
Old May 17, 2006 | 05:35 PM
hb_guy's Avatar
anyone?
Old May 17, 2006 | 05:51 PM
I meant chip a 5 speed pm6
Old May 17, 2006 | 05:55 PM
hb_guy's Avatar
what i am trying to ask is - if i modified my ps9 ecu would it basically be like a pm6 ecu? and should i do it/is it worth it? hope that clears it up..
thanks for the opinions everyone
Old May 17, 2006 | 06:02 PM
user 72830283's Avatar
PM6 manual ecu's are gonna be cheaper..easier for you rather then getting the auto ECU modded/chipped and crap..
Old May 17, 2006 | 06:27 PM
silentdork818's Avatar
Default Re: (pr3d)
You should sell the ps9 for some $$$...
Old May 17, 2006 | 11:06 PM
hb_guy's Avatar
thanks everyone
See Are X
Dec 11, 2010 05:15 PM
blasterman87
Nov 30, 2010 03:35 PM
ek_will
May 4, 2003 07:24 PM
altoid
Nov 3, 2002 11:34 AM
