need a picture as to filling tranny fluid.
I need a godd picture/and or discription as to where I fill my tranny fluid. It is on a 92 civic DX (5spd)
if you have anything it'd help alot.
Or you can just fill it from the Vehicle Speed Sensor location. Remove the VSS, stick a funnel in the hole, and fill with tranny fluid. Then remove the OEM fill hole bolt and check to make sure that the fluid inside the tranny is level with that hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street Ghost »</TD></TR><TR><TD CLASS="quote">Or you can just fill it from the Vehicle Speed Sensor location. Remove the VSS, stick a funnel in the hole, and fill with tranny fluid. Then remove the OEM fill hole bolt and check to make sure that the fluid inside the tranny is level with that hole.</TD></TR></TABLE>
^^^If you don't know what your doing though, i wouldn't reccomend removing the VSS...But that's just my opinion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc »</TD></TR><TR><TD CLASS="quote">
^^^If you don't know what your doing though, i wouldn't reccomend removing the VSS...But that's just my opinion</TD></TR></TABLE>
But the OP, "sleepermachanic 8", seems like he would know.
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
DBLAZE
Jun 6, 2005 04:37 PM
