im about to run open header
Old Apr 11, 2002 | 05:32 PM
FusionITR's Avatar
Default im about to run open header
j/k
but i need to take out my header, but it looks like i wont be able to jack the car up high enough to take it out. Will i be able to take it out at normal jack height?
Old Apr 11, 2002 | 05:34 PM
sackdz's Avatar
Default Re: im about to run open header (FusionITR)
Unless your jack is real low you should, tip it on it's side and slide it out.
Open header is a lot of fun and loud.
Old Apr 11, 2002 | 05:35 PM
Dr Pooface's Avatar
Default Re: im about to run open header (sackdz)
Isn't the stock header 2 piece?
Old Apr 11, 2002 | 05:37 PM
sackdz's Avatar
Default Re: im about to run open header (Ddub)
Yes, but if I remember right they're not easily seperated while on the car.
Old Apr 11, 2002 | 05:38 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah stock manifold is two pieces, it shouls easily slide out if you can lift the car up a little bit.
FusionITR's Avatar
im running usdm dc, its 1 peice
RedneckRicer
Apr 3, 2008 12:05 PM
prejdmlude
Nov 11, 2006 01:28 PM
IGotNoSwap
Sep 27, 2005 06:53 AM
98vtec
Welding / Fabrication
Mar 17, 2005 06:37 PM
ImporttRacerr555
Nov 25, 2003 02:13 PM
