Car will not start
Old May 16, 2006 | 03:54 PM
ED8REX's Avatar
Default Car will not start
Just got the car yesterday, drove it from my drive way into my garage with no problems. I notice that the ground coming from the left side of the car is looking rough. so i clean it up a bit and reconnect to the head. I reconnect the battery and try to start nothing. then i notice that i'm throwing codes 6, 10, and 13 anyone know what the hell is going on
Old May 16, 2006 | 04:32 PM
Tippyman's Avatar
Default Re: Car will not start (ED8REX)
http://www.c-speedracing.com/faq/05.php
Old May 16, 2006 | 04:56 PM
ED8REX's Avatar
i know what they mean but i dont understand why it wont start
Old May 16, 2006 | 05:19 PM
projsectEF's Avatar
does the engine crank over? when you turn the key to start the motor what does it do, what does it sound like? I might be able to help you if you answer those question. and as for the codes can't help you there buddy.
same **** happen to me, i got fucked over on my EF. I drove it home and found hella problems one is no start.
Old May 16, 2006 | 06:00 PM
Phshorty's Avatar
Default Re: Car will not start (projsectEF)
did you try the main relay?
Old May 16, 2006 | 07:10 PM
SFlCrx's Avatar
do u have spark,fuel,compression? that what u need
Old May 16, 2006 | 09:43 PM
ED8REX's Avatar
it cranks but doesnt turn over, i'm going to check the main relay and for spark tomorrow, it was compression test by the previous owner, and he said it pulled 190 across the board but seeing as how is said that the car didnt have any problems maybe i should double check that
Old May 17, 2006 | 02:06 AM
dxtosirex's Avatar
Default Re: (ED8REX)
my buddy just went throu that same prob in his 91 hb zc. he changed the dis,starter,battery,alt. and non of that worked. i just was the main relay. check behind your coin holder to find it.
F20b97AccordLx
Jan 16, 2023 10:15 AM
duscar
Apr 19, 2011 05:51 AM
importnoodles
Sep 28, 2006 12:22 PM
civic_geek_133
13
Jul 22, 2003 01:09 PM
patastinky
Sep 4, 2002 06:51 PM
