Need to find cheap pressure sender/transducer w/ 0-5v output
Does anyone out there know where to find a cheap pressure sender/transducer with a 0-5v output. I plan on using it to datalog the water pressure in my water/meth injection as a failsafe. I was going to use the stock oil pressure sender but I think most of the are ohm outputs rather than volts. I have found a few online but they are typically $100+.
Thanks.
Thanks.
LST2
May 16, 2006 11:50 AM
