mastercyl. brace......yup i made one
Old Apr 11, 2002 | 03:09 PM
Johnny Tran's Avatar
Default mastercyl. brace......yup i made one
i know most dont take me seriously, but believe me when i tell you i made one out of stuff around my engine bay, it looks factory, and works. only one problem, one hole must be drilled at the moment. im looking at ways around this now for those that care .......ill keep you all updated!
when ive completed it for good, ill take pics.
Old Apr 11, 2002 | 03:13 PM
Back in Black's Avatar
Rather OG
Default Re: mastercyl. brace......yup i made one (Johnny Tran)
Nice, but just one question...
How on Earth did you make time for that when you've been preparing for Race Wars?
RStoR's Avatar
Are "Country Club" cans stiff enough for that?
Old Apr 11, 2002 | 03:16 PM
Default Re: mastercyl. brace......yup i made one (RStoR)
nope.....but i bet the "piece" i used will be there if a bomb went off in the engine bay..the firewall will break off before this thing does
Old Apr 11, 2002 | 03:20 PM
EagleR's Avatar
Old Apr 11, 2002 | 03:22 PM
MiaToretto's Avatar
Does this mean that you are all dirty?!?!
Old Apr 11, 2002 | 03:24 PM
Rather OG
Default Re: mastercyl. brace......yup i made one (MiaToretto)
Old Apr 11, 2002 | 03:45 PM
Dr Pooface's Avatar
Default Re: mastercyl. brace......yup i made one (darth vadeR)
Need.......more........info.........
Old Apr 11, 2002 | 03:46 PM
ITR764's Avatar
good work nick . i knew you could do other things than just being a smart azz . look forward to the pics. i like anything that is factory looking.
Old Apr 11, 2002 | 03:51 PM
chad's Avatar
Moderator
cmon mia....we know nick didn't get dirty!!
Old Apr 11, 2002 | 05:21 PM
Default Re: mastercyl. brace......yup i made one (Chad)
well, as it stands, one hole will need to be drilled for this brace to work, and then tapped for threads.all easily done in a hour or less. looks like it should be there, and seems to function as intended.
i would say more about it, but i want to be the guinnea pig in case something fails. i might try to find one of the local "boyz" with an arrr to see if the setup is the exact same or will need to be modified.
-nick
Old Apr 11, 2002 | 06:00 PM
done's Avatar
good luck, hope it comes out well
Old Apr 12, 2002 | 03:34 AM
Default Re: mastercyl. brace......yup i made one (Jordo)
TTT for the Am/work crew....
Old Apr 12, 2002 | 03:51 AM
Willard's Avatar
work?
Pics of the stunna piece please...
Will
-who would like to brace his chit
Old Apr 12, 2002 | 04:28 AM
sackdz's Avatar
Default Re: mastercyl. brace......yup i made one (Willard)
Lets see some pics, masterbracor.
Old Apr 12, 2002 | 04:49 AM
Default Re: mastercyl. brace......yup i made one (sackdz)
i dont have any way (at the moment ) to take pictures, but take a look at the cast iron upper bracket for your power steering pump. remove this piece.or if your like me, take a spare out of your closet
if you look at this piece, there is an elongated hole for the "pump" to slide up and down on to tension the belt. this will be used as the actual brace for the MC. once you position this correctly, you will notice on the shock tower "chassis unibody" that exactly one 10mm bolt will line up perfectly. put this bolt in slightly! its a bitch to take out later with an open end wrench, trust me.
with this bolt in you will plainly see that another hole must be drilled to hold the rear portion of the "brace". drill this hole, and tap threads. i myself used a 12mm bolt as thats what i had, and i wanted it to be fairly sturdy.
it fit perfectly on my civic, doesnt look "ghetto" and seems to get the job done. Ive removed it since to get some pictures (eventually) and possibly take it to a machine shop to make it look more Bling Bling.
hopefully that helps out.......post questions, ill be happy to help.
-nick, whos sometimes helpfull and serious
Old Apr 12, 2002 | 04:52 AM
Willard's Avatar
buwahhhh
Will
-who likes a good joke early in the morning....
Old Apr 12, 2002 | 04:54 AM
buwahhhh
Will
well, it was an attempt ....but the post was serious
Old Apr 12, 2002 | 05:22 AM
sackdz's Avatar
Damn, does this mean I can't make the ghetto brace until I get a CX rack in? I kinda need that piece at the moment. NIce work, MacGyver
Old Apr 12, 2002 | 05:24 AM
junkyard is your friend
Old Apr 12, 2002 | 05:26 AM
RStoR's Avatar
we can meet up tomorrow and I can take a few pics for you. could also see if the brace fits the R. shoot me your # on IM if your interested.
Old Apr 12, 2002 | 05:37 AM
sent you an IM.....
Old Apr 12, 2002 | 06:00 AM
Splat's Avatar
Collector-o-Guns and Drinker
What the hell is it with chicks and dirty guys?!? I swear, Bef makes me change oil or do something every weekend
Old Apr 12, 2002 | 06:01 AM
Willard's Avatar
Default Re: mastercyl. brace......yup i made one (itr009)
stinky nads?
funky pits?
nappy hair?
Will
Old Apr 12, 2002 | 06:05 AM
sackdz's Avatar
Last time I checked, there was no salvage yard within a 50 mile radius of me that had a DC2.
[Modified by sackdz, 10:05 AM 4/12/2002]
