jdm seats into EK.. what about seatbelt sensor?
Old May 15, 2006 | 08:55 PM
ieatrice's Avatar
Default jdm seats into EK.. what about seatbelt sensor?
ok, i just picked up a set of jdm GSR seats. the seat belt sensor is on the passenger (jdm driver) side.. so is there anyway i can swap it over to the driver side (jdm paseenger) so the seat belt light on my cluster turns off when i put on my seat belts?
Old May 15, 2006 | 09:53 PM
john666's Avatar
Default Re: jdm seats into EK.. what about seatbelt sensor? (ieatrice)
can't you just remove the buckle and put it on the other side ?
Old May 15, 2006 | 10:24 PM
ieatrice's Avatar
Default Re: jdm seats into EK.. what about seatbelt sensor? (john666)
wouldn't it be backwards
Old May 15, 2006 | 10:36 PM
BlueIntegraBoy's Avatar
Put your stock EK seatbelt onto the driver seat.
Old May 15, 2006 | 11:03 PM
john666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't it be backwards</TD></TR></TABLE>
sure it would, but i dont think it would be a problem if it fit and all.
Old May 16, 2006 | 09:15 PM
ieatrice's Avatar
gsr seats don't bolt up into ek's like stock, so i ended up swapping the complete rails over including the seat belts and sensor! woot, problem solved\
RESULT:
Old May 16, 2006 | 09:43 PM
BALLIN H22 EK's Avatar
just pull the bulb out of the cluster
Old May 17, 2006 | 01:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">gsr seats don't bolt up into ek's like stock, so i ended up swapping the complete rails over including the seat belts and sensor! woot, problem solved\
Haha, that's true. I never figured that it was going into your EK. You would have to sway the inners rails anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK &raquo;</TD></TR><TR><TD CLASS="quote">just pull the bulb out of the cluster </TD></TR></TABLE>
Or unplug the plug from under the seat. The light won't come on.
Old May 17, 2006 | 01:50 AM
jdm_bones's Avatar
Default Re: jdm seats into EK.. what about seatbelt sensor? (BlueIntegraBoy)
Unbolt it and swap the right to the left...There is a bolt that holds the seat belt locking engagement. becareful when pulling out the sensor wire...
Old May 17, 2006 | 10:19 AM
bebfsu1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Or unplug the plug from under the seat. The light won't come on.</TD></TR></TABLE>
That's the easy way to do it. If you don't plug in the plug then the dash light won't come on at all, even if the seatbelt isn't buckled.
Old May 17, 2006 | 01:04 PM
ieatrice's Avatar
Default Re: jdm seats into EK.. what about seatbelt sensor? (bebfsu1)
yeah, i just swapped the inner rails!
o0ohaviko0o
Dec 12, 2007 08:26 AM
Panda0000
Feb 5, 2007 05:31 PM
GAME OVER 2007
Sep 30, 2006 10:38 AM
dut
12
Feb 14, 2006 10:50 AM
GetawayInMoscow
Jan 25, 2006 02:19 PM
