Weird electrical issue.
Old May 15, 2006 | 07:03 PM
OrangeBoost's Avatar
Default Weird electrical issue.
Since I put the new engine in I havent been able to get it started. The electrical stuff has been acting weird, the starter doesnt go and today when trying it there was huge sparking in where my oil line touches my valve cover.
I have a 2 guage cable from the starter bolt and the stock ground from the valve cover.
Any suggestions?
Old May 15, 2006 | 08:22 PM
Runnerdown's Avatar
Default Re: Weird electrical issue. (OrangeBoost)
where is the 2 gauge cable going?. you need to be very specific. eletrical diagnosis over the internet is tough
Old May 16, 2006 | 03:58 AM
The 2 guage cable is going from the starter bolt that goes into the tranny to the side of the engine bay (a hole where a hardline bracket was bolted down).
Old May 16, 2006 | 07:05 AM
old man neri's Avatar
Default Re: (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">The 2 guage cable is going from the starter bolt that goes into the tranny to the side of the engine bay (a hole where a hardline bracket was bolted down).</TD></TR></TABLE>
So you have something from the starter going to ground? That's not right. Anything that comes from the starter should go to the Positive on the battery.
Old May 16, 2006 | 07:55 AM
Default Re: (old man neri)
I dont understand how it would be diff than grounding the tranny, starter bolt goes into tranny so shouldnt it all have the same effect?
Old May 17, 2006 | 03:41 AM
bump
Any suggestions? The car is sitting here dieing to be tuned but I cant get it to start!!
Old May 17, 2006 | 05:17 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">I dont understand how it would be diff than grounding the tranny, starter bolt goes into tranny so shouldnt it all have the same effect?</TD></TR></TABLE>Neri's talking about the big battery (+) wire to the hot terminal on the starter. You're talking about a big tranny ground (to chassis). You need both, along with a good ground from battery (-) to chassis...
Again, you have to be very specific about what you're describing.
Old May 17, 2006 | 08:22 PM
Ok so can someone at least give me a starting point or some kind of tests? im desperate and have no clue what to do at this point.
Old May 17, 2006 | 09:08 PM
integraswtrde's Avatar
voltage meter,you know how to use one?put it on on dc 20 and start checking ground/power.
DarrenWB
Jul 1, 2019 05:28 AM
patrickstar
Other Make Vehicles
Apr 3, 2010 06:53 AM
DEPintheCurve
Dec 30, 2009 12:19 PM
jontsi95
Apr 25, 2008 06:14 PM
pat92si
Aug 13, 2007 11:51 AM
