Rear disc Conv. question HELLLLLLPP meeee
Old May 15, 2006 | 06:59 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Default Rear disc Conv. question HELLLLLLPP meeee
hi guys well i have a 95 civic hatch dx and i wanted to change the drum to disc
(((((question)))))
what do i need to change it to disc ???
i know i need to get a integra rear disc assembly or si assembly
do i need a different brake line ???
if i take it off my self and change would i expletive up my allignment ?
help out guys thanks
Old May 15, 2006 | 08:14 PM
Runnerdown's Avatar
Default Re: Rear disc Conv. question HELLLLLLPP meeee (spoon95eg)
complete rear trailing arms with disc and caliper with brake lines are needed. use the red search button in the corner of the screen, this topic has been covered a billion times. also, try http://hmotorsonline.com/shop/whatsnew.php this guy has very clean parts with a bulletproof reputation
Old May 16, 2006 | 06:52 AM
TadoRacing's Avatar
you need the e-brake cable
Old May 16, 2006 | 08:30 AM
spoon95eg's Avatar
B A N N E D
Default Re: (TadoRacing)
So I need to buy the rear complete trailing arm brake lines came from si civic or integra ebrake lines and that's it ????
So I really need to get the complete set??
Can somebody confirm this and explain it to me more I appreciate it thank you
Old May 16, 2006 | 04:37 PM
XkjeldorX's Avatar
Default Re: (spoon95eg)
like they have said, search is ur friend but ill help anyways.
you need to get the complete rear trailing arm off of a 00 civic si or 94-01 integra. u can also use the DA integra rear trailing arm but i wouldnt recommend unless u plan to replace TA bushing and the rear hub/bearing assembly cuz of the age of the RTA. what ever TA's u get i reccomend to replace the TA bushings.
you will also need the brake lines and e-brake cables. if u do use the DA trailing arm u need to keep ur LCA's. I replaced everything while i was at it, rotors,pads, LCA, TA bushings. if u have any more questions i can send me a PM and ask me.
Old May 17, 2006 | 10:38 AM
j spec's Avatar
Default Re: (XkjeldorX)
just for some extra insight you do not have to replace the rear trailing arm (although it is easier) the disc assembly rear spindle will bolt to the drum trailing arm. however the whole spindle needs to be swapped by removing the 5 or 6 star drive bolts and the spindle nut that holds it to the trailing arm. this method may be preferred because most people replace the compensator arm and throw out their tow settings. i have ran into this problem because the rear discs i purchased ended up being slightly bent on one side and the tow could not be adjusted any more i did not realize this till i had an allignment done months after my purchase so i replaced the bent arm with my factory drum rear trailing arm.
Old May 17, 2006 | 10:46 AM
spoon95eg's Avatar
B A N N E D
Default Re: (roma's GSReg6)
Nice info
So if I can get a disc caliper and the spindle and ebrake then I can do the swap cool
Old May 17, 2006 | 03:13 PM
XkjeldorX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 &raquo;</TD></TR><TR><TD CLASS="quote">just for some extra insight you do not have to replace the rear trailing arm (although it is easier) the disc assembly rear spindle will bolt to the drum trailing arm. however the whole spindle needs to be swapped by removing the 5 or 6 star drive bolts and the spindle nut that holds it to the trailing arm. this method may be preferred because most people replace the compensator arm and throw out their tow settings. i have ran into this problem because the rear discs i purchased ended up being slightly bent on one side and the tow could not be adjusted any more i did not realize this till i had an allignment done months after my purchase so i replaced the bent arm with my factory drum rear trailing arm. </TD></TR></TABLE>
this is true and it is much easier than replacing the whole trailing arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg &raquo;</TD></TR><TR><TD CLASS="quote">Nice info
So if I can get a disc caliper and the spindle and ebrake then I can do the swap cool</TD></TR></TABLE>
u would need the whole spindle- hub/bearing assembly. also brake lines, pads and rotors and ebrake cables
Old May 17, 2006 | 03:21 PM
02 accord's Avatar
tow: To draw or pull behind by a chain or line: a tugboat towing a barge. See Synonyms at pull.
I wonder how you can adjust tow on a car...
mynameizstitch
10
Dec 13, 2009 03:06 PM
ek4hatch
Jul 9, 2004 09:14 PM
MugenHonda
Jun 12, 2003 05:14 PM
JICB16B
Feb 27, 2003 06:38 PM
