4 wire oxygen sensor wiring
Old May 15, 2006 | 06:43 PM
downest's Avatar
Default 4 wire oxygen sensor wiring
Trying to install my 4-wire o2, and I can't find a good guide that gives the right pins to route everything to. My sensor is the Bosch 4-wire with 1 black, 1 grey and 2 whites. The paper in it says black is the signal, whites are the heater and grey is ground.
Here's what I have done:
Sensor harness
Black Old oxygen sensor wire
White1 A6 (OBD1 harness)
White2 Ground on T-stat housing
Grey Ground on T-stat housing
still throwing a code 41.
Old May 15, 2006 | 08:19 PM
Runnerdown's Avatar
Default Re: 4 wire oxygen sensor wiring (downest)
the two whites. one is sensor power, the other is sensor heater. thats your problem, its not suppose to be grounded in two spots. which white wire doesnt matter. they both get the 12v
Sereth
Honda Civic (2001 - 2005)
Aug 23, 2017 01:12 AM
orlandoEM2
Mar 23, 2010 07:23 PM
downest
11
May 17, 2006 10:10 PM
Audipwr1
Jun 23, 2003 01:00 PM
