Is this true?
Old May 15, 2006 | 04:24 PM
redej878's Avatar
Default Is this true?
My friend tells me that you don't need any O2 sensors if you have a chipped or Stand alone ECU, is this true?
Old May 15, 2006 | 04:29 PM
Relic1's Avatar
Setting the map to run without the primary O2, your engine will be directly running on the maps in the ECU. If the maps are tuned perfectly you will have no problems.
BUT if they are off a little bit or something happens that causes the the car to run lean it will damage the engine quickly. A primary O2 would remove this chance.
Seriously... run the primary O2 (first one) there is no reason to not run it.
Dogginator's Avatar
Daisy... Daisy...
Default Re: Is this true? (redej878)
I suppose that you could make it run on preset maps. (I think that is open loop.) However, 99.999999999999% of people would use the primary O2 sensor or a wideband O2 sensor.
Old May 15, 2006 | 04:36 PM
redej878's Avatar
Default Re: Is this true? (Dogginator)
He told me that the guy chipping and tuning his ECU told him its pointless to run an o2 sensor.
Old May 15, 2006 | 05:07 PM
NJIN BUILDR's Avatar
Lots of people run open loop with standalones.I run Hondata in my daily driver open loop.I have a wideband O2 in the car but I just use it for tuning.
Old May 21, 2006 | 04:53 AM
thahuhstunna's Avatar
i think your friend is talking out his a*s
Old May 21, 2006 | 09:10 AM
Default Re: Is this true? (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">i think your friend is talking out his a*s</TD></TR></TABLE>
I'm afraid your the one that doesn't know wtf your talking about.
Old May 21, 2006 | 04:28 PM
Default Re: Is this true? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I'm afraid your the one that doesn't know wtf your talking about.</TD></TR></TABLE>
what the hell are you talking about??
Old May 21, 2006 | 06:32 PM
HiProfile's Avatar
I could say I live by breathing nitrogen - and I wouldn't be wrong. It would sound wrong though.
Same here - you don't *need* an o2 sensor, but its so easy/cheap to run one, that there's no reason not too. An hour of some tuning and a good IAT-correction function will get you by, but an o2 will get you better gas milage usually.
Old May 21, 2006 | 10:16 PM
Default Re: Is this true? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I could say I live by breathing nitrogen - and I wouldn't be wrong. It would sound wrong though.
Same here - you don't *need* an o2 sensor, but its so easy/cheap to run one, that there's no reason not too. An hour of some tuning and a good IAT-correction function will get you by, but an o2 will get you better gas milage usually.</TD></TR></TABLE>
^^ re-read the original post... his boy is speaking in poo
Old May 22, 2006 | 12:18 PM
Walterronny's Avatar
you cant problems but normally the most people run with o2 sensor or a wideband...
BoldFart16
Engine Management and Tuning
12
Mar 12, 2011 06:09 AM
88 EF Hatch
Sep 23, 2009 07:23 PM
ken2830
Feb 1, 2008 12:09 AM
portenio78
Jun 1, 2006 04:00 PM
senpai
Oct 16, 2004 10:21 PM
