Removing steering wheel in 88 CRX Si, how?
Old Apr 11, 2002 | 02:17 PM
travis's Avatar
Default Removing steering wheel in 88 CRX Si, how?
Since I haven't found a helms yet, I was hoping someone could help me with this steering wheel removal. What's the trick? Thanks!
Old Apr 11, 2002 | 02:19 PM
.MilanoRex's Avatar
Default Re: Removing steering wheel in 88 CRX Si, how? (ITR#231)
get a knife and take the little "H" thing in the middle of the steering wheel out, then get a 19mm socket and unscrew the screw thats in there.
Old Apr 11, 2002 | 02:24 PM
travis's Avatar
Default Re: Removing steering wheel in 88 CRX Si, how? (crXtreme)
Ha ha ha!! The "H" comes out!!! How easy!!
You guys wouldn't beleive what I have been trying
Got it...thanks!
Old Apr 11, 2002 | 04:31 PM
Cryptopsy's Avatar
Got it...thanks!
So what were you trying???
Old Apr 11, 2002 | 04:40 PM
travis's Avatar
Default Re: Removing steering wheel in 88 CRX Si, how? (SoulflyCRXsi)
LOL! You have to understand that all of the other honda wheels that I have removed have had air bags. With those, you have to remove a bunch of little panels on the side to get to some torx bolts, and then you remove the bag from the front. That gets you to the 19mm bolt. Sooooo, I just figured that I would have to remove the entire horn button piece in order to get to the 19mm bolt. How would you go about doing that? Well, I removed the column covers and was busy removing screws backwards from inside of the wheel cover with a variety of screwdrivers and angle adapters. I actually got so much of it apart that it's going to take me a while to put it back together now that the wheel is out Finally, when I saw that I wasn't making any progress with all of these screws I posted the question. I'm glad I did.
89civichb20b
Sep 13, 2015 11:11 AM
Mr.CRXsi
Aug 21, 2010 10:06 PM
05civicdriver
Honda Civic (2001 - 2005)
13
Apr 13, 2007 03:35 PM
dustin_crxsi
Oct 30, 2006 05:29 PM
hondatuner20
Jan 17, 2006 01:37 PM
