90 Accord Rust On rear fender...
Old May 15, 2006 | 12:59 PM
standbackimapro's Avatar
Default 90 Accord Rust On rear fender...
I have a 90 accord, and i got a huge patch of rust on the rear fender, the cars old so i dont wanna pay 1000 dollars for a body shop cuz its not worth it, So im gonna do it myself
the rust is about 4 inches, i wanted to cut out all the rust, cut out a piece of sheet metal to fit the hole, then get some magnets to hold the piece in place, and put a few spot welds, then bondo over it..
i have minimal body work skills, so if that sounds wrong, than my mistake..
But what would be the right way to do it?
Old May 15, 2006 | 01:46 PM
Mangotreemechanic's Avatar
Default Re: 90 Accord Rust On rear fender... (standbackimapro)
Cut out the rust, leaving as much as possible of the body lips and design (so you don't have as much trouble duplicating them). Cut your replacement sheetmetal to overlap the area. Indent the body edges to be covered by the sheetmetal so you can maintain as much a possible of the same lines of the original. Spot weld, tack weld, or braze the patch sheetmetal in place. Use bondo to fill in the low spots. Do your magic to contour it like the original. Do your painting and finish. You're done.
andyxle
Jun 30, 2009 11:35 AM
dumpedhard
Mar 16, 2009 04:22 PM
globeDELETETHIS USER
Aug 7, 2006 10:12 AM
go2sleep
May 18, 2006 06:36 PM
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
