Which spindles for JDM ITR motor?
Old May 15, 2006 | 10:55 AM
JDM_ITR's Avatar
Default Which spindles for JDM ITR motor?
im guessing they all are the same for integras ie ls, gsr, itr - i just wanted to double check.. thanks
Old May 15, 2006 | 11:17 AM
SilverDc2's Avatar
Default Re: Which spindles for JDM ITR motor? (JDM_ITR)
any b series axles fit, its the hub/spindle (where your rotor is) is what changes,
if you have a usdm suspension you should be good
Old Jun 11, 2006 | 09:53 AM
JDM_ITR's Avatar
Default Re: Which spindles for JDM ITR motor? (SilverDc2-Ap1)
hey thanks for the response man. i really appreciate it.
Old Jun 11, 2006 | 04:38 PM
hypeR speed's Avatar
can anyone else confirm this? last i heard jdm splines are 36mm compared to 32mm usdm. i would assume that the axles are different as well iirc.
Old Jun 11, 2006 | 05:35 PM
hayabusa160's Avatar
Default Re: Which spindles for JDM ITR motor? (turbo y0)
98+spec jdm itr uses the bigger spline.
Old Jun 12, 2006 | 09:09 AM
YumVTEC's Avatar
Default Re: Which spindles for JDM ITR motor? (hypeR speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypeR speed &raquo;</TD></TR><TR><TD CLASS="quote">can anyone else confirm this? last i heard jdm splines are 36mm compared to 32mm usdm. i would assume that the axles are different as well iirc. </TD></TR></TABLE>
that difference is in the wheel hub, and the outter end of 98+ spec JDM ITR axles. if you are not using 98+ spec JDM 5-lug wheel hubs (36mm) then you can run standard axles.
Terrible One
Mar 19, 2005 06:19 AM
1.8LHatch
Jul 31, 2004 08:16 PM
Project99EK
Mar 13, 2004 09:04 AM
jdmjohn02
Jan 10, 2004 06:36 PM
rockwilda
Dec 14, 2002 11:11 PM
