Your opinions on block guards?
Old May 15, 2006 | 10:46 AM
b16nonoy's Avatar
Default Your opinions on block guards?
Do you think the block guards really save yourself some money? or do you think they arent worth a ****??
I got one welded in my block...
Darton ductile sleeves w/ nuformz block guard welded in.
Modified by b16nonoy at 11:58 AM 5/15/2006
Old May 15, 2006 | 10:47 AM
Chris22215's Avatar
Default Re: Your opinions on block guards? (b16nonoy)
are those aftermarket sleeves?
Old May 15, 2006 | 11:05 AM
mike-y's Avatar
Default Re: Your opinions on block guards? (Chris22215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris22215 &raquo;</TD></TR><TR><TD CLASS="quote">are those aftermarket sleeves?</TD></TR></TABLE>
"Darton ductile sleeves w/ nuformz block guard welded in"
The only issue I have heard about is uneven heat dissipation at the top of the cylinder where the blockguard is (it gets hotter than the rest of the cylinder). However, I can not confirm that this is actually a problem, perhaps someone else who has experience with one can chime in.
Old May 15, 2006 | 11:12 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Your opinions on block guards? (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">
That, and the arguments about how to actually put them in the block. Welding is said to distort the cyinders.
Old May 15, 2006 | 11:41 AM
Orangecivic251's Avatar
Default Re: Your opinions on block guards? (JDM_Ej)
not sure but i do know that block looks clean
Old May 15, 2006 | 03:00 PM
ExospeedAMcrx's Avatar
BLock guards are pointless, especially since you have sleeved already. The block isnt going to be any stronger with the welded block guard. The Iron Ductile is good enough for so much power, and its a waste of money to do the block guard.
We've pushed 900hp on Open deck sleeves and All Motor guys are doing Open deck all the time with super big bores.
Old May 15, 2006 | 05:13 PM
drift4jesus's Avatar
Default Re: Your opinions on block guards? (exospeedAMcrx)
looks to me like it would be pretty restrictive for coolant flow.
I'd prefer posting over a block guard.
TravisBiggie
Oct 18, 2013 05:08 AM
RYan McG.
Nov 29, 2006 09:48 AM
asubennett
10
Mar 20, 2005 09:20 PM
GreddySi99
Oct 15, 2003 09:35 AM
