b18c5 into eg origionally d15b
Old May 15, 2006 | 01:45 AM
wez's Avatar
wez
Default b18c5 into eg origionally d15b
hi there,
planning on swapping a b18c5 into my eg civic but im fairly new to this, ive swapped various engines but only of the same type. I ve never swapped and engine for a complete different one.
how much work is involved in a swap like this?
I just got a price for a b18c4 has this is the only one they have in at the moment and gave me a price of £1000 for the engine with 48k on it, dixxy, ecu, tranny, driveshafts and manifold and downpipe. (dont think theres anything else i need unless i need the wiring loom, the b18c4 is coming out of a 98 model but my eg is a 91 jdm d15b)
is the b18c4 any different to the b18c5 besides the red rocker cover.
what mountings will i need
Old May 15, 2006 | 04:47 AM
ku's Avatar
ku
Default Re: b18c5 into eg origionally d15b (wez)
the c4 should bolt straight in dunno about the c5
Old May 15, 2006 | 05:07 AM
JdmLub's Avatar
Default Re: b18c5 into eg origionally d15b (ku)
ur going from d-b,
u will need
b-series mounts
b-series axels
b-sereis shift linkage
and u can use ur harness...
look up swaps in "search" they will have everything u need to know
Old May 15, 2006 | 07:02 AM
EGin6's Avatar
i've never herd of a b18c4
Old May 15, 2006 | 07:57 AM
wez's Avatar
wez
Default Re: b18c5 into eg origionally d15b (JdmLub)
i did mate i looked it up first but no b18c4 in there, according to the other forumn there hard to get old of, found out that the b18c4 is around 170 to 180 bhp where as the b18c5 is 195 i think, but i'd rather lose the extra 15bhp or so if the c4 will bolt straight in. Will the mounts still be in the same place??
cheers u lot for ur halp so far... very much appreciated
Old May 15, 2006 | 08:16 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wez &raquo;</TD></TR><TR><TD CLASS="quote">i did mate i looked it up first but no b18c4 in there, according to the other forumn there hard to get old of, found out that the b18c4 is around 170 to 180 bhp where as the b18c5 is 195 i think, but i'd rather lose the extra 15bhp or so if the c4 will bolt straight in. Will the mounts still be in the same place??
cheers u lot for ur halp so far... very much appreciated</TD></TR></TABLE>
This is dumb logic. B-series motors are virtually identical, if your looking at it from a swap standpoint.
If you want to swap the B18C5 into a EG, Its pretty straight forward. I'm going to assume you have the entire swap ready like this:
B18C5 Engine and Transmission (complete) with all mounts, linkage and engine harness.
B-series axles (From any 94+ Integra or B-series civic/del Sol)
OBD1 Distributor from a B16 or B18.
OBD1 Injectors (maybe)
Its pretty much a bolt-in process.
Old May 15, 2006 | 09:46 AM
Targa250R's Avatar
be professional
Default Re: (EGin6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGin6 &raquo;</TD></TR><TR><TD CLASS="quote">i've never herd of a b18c4</TD></TR></TABLE>
It's equivalent to a B18C1.
Old May 15, 2006 | 09:52 AM
Out of every
Default Re: b18c5 into eg origionally d15b (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">This is dumb logic. B-series motors are virtually identical, if your looking at it from a swap standpoint.
Its pretty much a bolt-in process. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">It's equivalent to a B18C1.</TD></TR></TABLE>
b18c4 is found in europe or something
Old May 15, 2006 | 09:56 AM
7mile's Avatar
Default Re: (Targa250R)
can you prove that?
Old May 15, 2006 | 09:58 AM
Out of every
Default Re: (7mile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7mile &raquo;</TD></TR><TR><TD CLASS="quote">can you prove that?</TD></TR></TABLE>
its a gsr motor. just different country diff number thats it.
does not need to prove that i second it
Old May 15, 2006 | 10:15 AM
Targa250R's Avatar
be professional
Default Re: (7mile)
Yes.
Old May 15, 2006 | 10:17 AM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
I don't think you can.
Old May 15, 2006 | 10:20 AM
Targa250R's Avatar
be professional
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you can.</TD></TR></TABLE>
That's okay, you can think whatever you want.
Old May 15, 2006 | 10:24 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">That's okay, you can think whatever you want.</TD></TR></TABLE>
You can't think whatever I think i'm thinking you're thinking.
Old May 15, 2006 | 10:25 AM
Out of every
http://www.hondaworld.ru/honda_civic_202.htm
there you go look at the hp specs its really not that accurate but hey the numbers are relatively close to the gsr
Old May 15, 2006 | 10:28 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">You can't think whatever I think i'm thinking you're thinking.</TD></TR></TABLE>
That's what I thought.
Old May 15, 2006 | 10:51 AM
wez's Avatar
wez
ok so am i better waiting for a b18c5????
Old May 15, 2006 | 10:52 AM
Out of every
Default Re: (wez)
yes
z6hatchboy
Sep 3, 2008 10:03 AM
sawedoffcoupe
12
Jun 30, 2008 06:32 PM
D16SohcVtec
14
Jan 15, 2008 04:49 AM
GSR-C5
Sep 13, 2005 10:05 AM
