can there be too light of a fly wheel?
Old May 14, 2006 | 10:55 PM
1995sir's Avatar
Default can there be too light of a fly wheel?
aight so i orderd a 9lb flywheel, i figured the lighter the better, but my boy told me that he has seen someone tryna go up a steep parking gurage and he wasnt able becuse the engine was bogging out? not enought rotational force or somthing...it doesnt sound right to me but im still not certifyed at HONDA eather?
Old May 15, 2006 | 03:01 AM
naTRON's Avatar
when it's too light, you can rev it up and then slow down quickly... like at a stop light or something, and the car will shut off.... not enough rotational force to keep things turning... not sure about the parking garage thing though
Old May 15, 2006 | 09:33 AM
Lsos's Avatar
Default Re: can there be too light of a fly wheel? (1995sir)
I could see it being a problem if the accepted technique for going up a steep hill was to redline the engine, close your eyes, and drop the clutch, letting the flywheel's momentum carry the car up.
However, if the driver of the car used the engine to drive up the hill, I don't see how it could be a problem...
Old May 15, 2006 | 10:14 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: can there be too light of a fly wheel? (Lsos)
The problem here is the point between shifts. With a flywheel thats TOO light, your engine will drop out of optimal range when you shift, resulting in you loosing power and time.
The ideal flywheel weight would be between 9-12lbs.
Old May 15, 2006 | 03:42 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: can there be too light of a fly wheel? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">The problem here is the point between shifts. With a flywheel thats TOO light, your engine will drop out of optimal range when you shift, resulting in you loosing power and time.
The ideal flywheel weight would be between 9-12lbs. </TD></TR></TABLE>
Are you supposed to lift off of the throttle when you shift?
Old May 15, 2006 | 05:48 PM
Smash03's Avatar
Default Re: can there be too light of a fly wheel? (Dogginator)
I read somewhere that if the flywheel is too light, you can actually lose inertial toqrue.
Old May 15, 2006 | 05:53 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: can there be too light of a fly wheel? (Smash03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smash03 &raquo;</TD></TR><TR><TD CLASS="quote">I read somewhere that if the flywheel is too light, you can actually lose inertial toqrue.</TD></TR></TABLE>
That is true.
Old May 15, 2006 | 07:55 PM
1995sir's Avatar
aight so im good running a 9lb fly wheel, just making sure
Old May 15, 2006 | 08:02 PM
Nexus Flux's Avatar
I completly agree. It really depends on what you use the car for.
(Daily driver) Street = you are going to have to use something a little heavier so you don't screw up idle and start off
(Track) Racing = go with a light wheel since RPMs won't drop much below 4-5K, and you get best acceleration due to reduced rotating mass
That's my two cents, but hey it's a free country, due wht you want.
Old May 15, 2006 | 08:53 PM
category5 SI's Avatar
Default Re: can there be too light of a fly wheel? (Nexus Flux)
I have an 8lb flywheel,I think it's to light.
Old May 16, 2006 | 08:08 AM
1995sir's Avatar
Default Re: can there be too light of a fly wheel? (category5 SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by category5 SI &raquo;</TD></TR><TR><TD CLASS="quote">I have an 8lb flywheel,I think it's to light. </TD></TR></TABLE>
what about it makes you think its too light?
Old May 16, 2006 | 08:29 AM
b18sihatch's Avatar
i think that it isnt anything to worry about.
9lbs is a good point between too light and too heavy, basicly between super light and stock.
you shouldnt have any problems i had a hdss with a exedy 9lbs flywheel, the rev was alot faster than stock, but it wasnt anything that was undrivable or cause ANY problems, basicly just felt alot faster reving than stock
Old May 16, 2006 | 09:17 AM
Chiovnidca's Avatar
Default Re: can there be too light of a fly wheel? (b18sihatch)
I have a 6.3lb flywheel, 3puck solid hub disk, and an extra heavy duty presure plate. I wouldn't want to get caught in traffic with it.
Old May 16, 2006 | 09:30 AM
b18sihatch's Avatar
Default Re: can there be too light of a fly wheel? (Chiovnidca)
he brings up a good point. how the flywheel is will depend on what kind of a clutch you have
Old May 16, 2006 | 03:07 PM
1995sir's Avatar
im runnin a stage 1 organic from exedy
Chadted
Honda Civic (2006 - 2015)
Jul 14, 2009 10:06 AM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
JBuckland
Jul 18, 2008 10:41 AM
krotter
Jun 26, 2007 05:46 PM
Rice Ball
Apr 22, 2003 10:28 AM
