can you adjust idle?
Old Apr 11, 2002 | 11:40 AM
exr_pd's Avatar
Default can you adjust idle?
can you adjust the idle on a 89 civic dx stock. if so how do you do it?
Old Apr 11, 2002 | 11:46 AM
Urban Business
Guest
Posts: n/a
Default Re: can you adjust idle? (civictype4)
yes there is a screw on the throttle body that lets you do it
Old Apr 11, 2002 | 11:56 AM
JohnysZC's Avatar
Default Re: can you adjust idle? (TorteX)
it should be right under some vaccum lines. Right=lower idle (close) Left=Higher Idle (open). Try to get ahold of a tach and connect it to your Dizzy and battery just to make sure you dont go to low or to high. idel should be at 7800 .50 +/-.
Old Apr 13, 2002 | 02:06 PM
MNCRXSi's Avatar
Default Re: can you adjust idle? (JohnysZC)
7800 is a extremely high idle Try 750 +- 50
Old Apr 13, 2002 | 04:50 PM
89 CRX SI's Avatar
Default Re: can you adjust idle? (MNCRXSi)
actually 780
Old Apr 13, 2002 | 04:52 PM
Hcivic88's Avatar
Default Re: can you adjust idle? (89 CRX SI)
i think johnny meant 780, just hit the 0 too many times, al least i hope that what he did. i think the redline's at like 7000, lol
speedfanatic88
15
Aug 23, 2004 03:12 PM
Marcos
Apr 13, 2003 05:00 PM
350z-tech
Nov 10, 2001 10:46 PM
