Having problems starting my car
Old May 14, 2006 | 07:17 PM
DC4me's Avatar
Default Having problems starting my car
I need help asap... The problem is that when I try to start my car and I have my clutch engaged and I turn the car over I get nothing. No click or no sounds. All I see are all my instrument lights and radio turn on and turn off. I have to wait or go back and fourth with my keys until the car starts.. It started about a month ago and its happening for often now.. it took almost 10 minutes for me to get it started today.. If my explanation is confusing it's like not having your clutch engaged and you try to start your car and nothing happens. Thats whats happening to my car but I have my clutch engaged.. When it does turn over it turns over like a champ, I hope H-T can help me out and let me know what the problem is.. TIA
Old May 14, 2006 | 07:33 PM
RJonathan's Avatar
Default Re: Having problems starting my car (DC4me)
The problem with your car is that your negative on your battery terminal is either dirty or isnt tight enough. I had the same problem on my car. My negative terminal bolt was tighten down but it was still a tad lose so I grabed a screw and screw it in between the battery terminal and the negative nipple.
Old May 15, 2006 | 05:27 AM
DC4me's Avatar
Default Re: Having problems starting my car (RJonathan)
my battery is tight enough and it's clean.. so the battery is out of the question.. anybody else know what it could be.. i searched about starting problems and most ppl don't have the problem i'm having..
Old May 15, 2006 | 06:04 AM
JasonST's Avatar
If you thin your clutch might not be engaged fully or being read as engaged, you can look under the pedal, and theres 2 sensors, push the pedal fully down and it should hit the one on the far side of the clutch pedal, make sure it fully touches the sensor, theres a little plastic part of the sensor that goes up and down when pressure from the clutch pedal is applied to it.
Old May 17, 2006 | 03:13 PM
DC4me's Avatar
Default Re: Having problems starting my car (JasonST)
bump
Old May 17, 2006 | 05:06 PM
knomexx's Avatar
it could be your ignition switch your starter or your clutch switch. unplug the connector at the switch on your clutch pedal and jumper the two terminals. if it starts with the jumper in, it is the switch.
Old May 17, 2006 | 05:36 PM
GSR44's Avatar
i had the same thing happen to my integra when i still had it. my starter was going bad. there's a tutorial on teamintegra.net...shows you how to replace the internals of your starter w/ new ones. better than having to buy a new/remanufactured starter. hope this helps
Old May 17, 2006 | 05:50 PM
gs_rbaby's Avatar
fix or replace your starter, same problem happen to me too. Some times it would start too, but other times it was a real pain in the *** to get it to start.
Old May 17, 2006 | 06:00 PM
Snafubmx234's Avatar
Knomexx had the only reasonable answer.
It's probably your clutch switch. You can try starting the car by hooking the starter up to the batter directly. Take his advice.
To the person that said the clutch was too thin
Old May 17, 2006 | 07:42 PM
DC4me's Avatar
Default Re: (Snafubmx234)
Thanks for the help. If anyone else has anymore suggestions LMK. I'll check out what was suggested hopefully tomorrow or this weekend since I've been busy with school and haven't driven it since I made this post. If it turns out to be the clutch switch would I have to change it or is there a way to adjust it.. I haven't had much problems with the car the past 2 years I've had it and I want it to stay that way.
Danny_Flah
Oct 14, 2009 11:08 AM
PatrickGSR94
Apr 23, 2005 05:24 PM
ELHatchyBlanco
Jan 23, 2004 02:13 PM
quanek4
Sep 1, 2003 03:44 PM
Infamous_Imports
Sep 18, 2002 09:51 PM
