Suspension & Brakes Theory, alignment, spring rates....
ITR 22mm sway bar with ASR subframe brace..what endlinks to use?
Old May 14, 2006 | 06:09 PM
hi-Powered's Avatar
Default ITR 22mm sway bar with ASR subframe brace..what endlinks to use?
can i use my stock ones or do i need to use ITR ones.
the car is 00 si..
Old May 14, 2006 | 07:21 PM
downeyballz's Avatar
Default Re: ITR 22mm sway bar with ASR subframe brace..what endlinks to use? (hi-Powered)
i think you can use your stock ones, but im not sure. the best think to do is just try it . i need si end links if your getting rid of your, or i anyone has a part number
Old May 14, 2006 | 10:37 PM
Voyage34's Avatar
Default Re: ITR 22mm sway bar with ASR subframe brace..what endlinks to use? (downeyballz)
you can use your stock ones if when you got your asr brace, they included the aluminum bushings that fit inside the ends of the swaybar arms sizing them for the si endlinks. these:
Old May 15, 2006 | 12:58 AM
black cx's Avatar
Default Re: ITR 22mm sway bar with ASR subframe brace..what endlinks to use? (Voyage34)
i have the itr sway....and function 7 LCA's, what endlinks do i use?....where can i get those in the pics above ^^
Old May 15, 2006 | 08:20 AM
Voyage34's Avatar
Default Re: ITR 22mm sway bar with ASR subframe brace..what endlinks to use? (black cx)
you can use either your stockie SI endlinks or if you want, since youre already running one of their products, the F7 endlinks are very well made and pretty affordable.
im very happy with mine
Old May 15, 2006 | 08:42 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black cx &raquo;</TD></TR><TR><TD CLASS="quote">....where can i get those in the pics above ^^</TD></TR></TABLE>
Those spacers come in the A-Spec Racing subframe reinforcment kit. If your planning on using an ITR rear sway bar on an EK, you defiently need the whole kit. The EK subframe is super weak...
Old May 15, 2006 | 09:36 AM
hi-Powered's Avatar
how much and where can i get those F7 endlink?
Old May 15, 2006 | 11:12 AM
black cx's Avatar
anyone have pitcrews email address?
Old May 15, 2006 | 12:44 PM
WONG FRIED RICE's Avatar
yes u can use the stock endlinks. i personally recommend ASR subframe. Works nice, and looks good
Boomer234
Suspension & Brakes
Nov 17, 2006 12:08 PM
EMphaticONE
Nov 25, 2004 08:57 AM
zm_dawg
May 31, 2004 09:11 AM
speedemon
Jan 4, 2004 09:33 AM
xhatchracerx
Apr 10, 2003 06:57 AM
