Clunk from a stop
Sometimes, when I come to a stop, put it in gear, and let the clutch out about halfway there is a slight clunk from my engine bay. It can also be felt by passengers if they have thier feet on the ECU area. Now, since it dosnt happen all the time I think its just a motor mount being gay. I filled my front and rear with poly glue, and then thought it might be too still so i drilled holes in the poly. The front definatly squeeks, I'm thinking this is the rear's way of saying screw you?
Check your mounts like you said the front and back one, if broken then replace another thing i did for my crx is i got the poly motor mount inserts for like $25 works great puts the power the ground
Could be's
Ball joint
axle / bearing
A-arm bushings
Radius arm bushing
shift linkage
Exhaust hitting chassis
loose strut's
If you need more let us know
Ball joint
axle / bearing
A-arm bushings
Radius arm bushing
shift linkage
loose strut's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman »</TD></TR><TR><TD CLASS="quote">Could be's
Ball joint
axle / bearing
A-arm bushings
Radius arm bushing
shift linkage
loose strut's
adding...
loose front subframe bolts.
Ball joint
axle / bearing
A-arm bushings
Radius arm bushing
shift linkage
loose strut's
adding...
Filliam H. Muffman
43
Dec 25, 2022 02:57 PM
