Tensioner....I don't get it
The tensioner on my LS has two holes in the backing.....
The one on the left is for the spring but what do you do with the one on the left?
There's a threaded hole in the block that lines up with that hole but I don't remember a bolt being there originally. Does anyone know for sure??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">The tensioner on my LS has two holes in the backing.....
There's a threaded hole in the block that lines up with that hole but I don't remember a bolt being there originally. Does anyone know for sure??</TD></TR></TABLE>
There's a pin on the black that the hole is suppose to slide on. it's the pivot point for the tensioner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">Hmm...I think I might be using that pin to hold the spring. Does the spring hook to a similar pin?
Could I use a small bolt to hold the spring?</TD></TR></TABLE>
The spring goes to another pin, but it's notched. there's a solid non-notched pin the tensioner slides onto. the only bolted part of the tensioner is the center hole. I believe it's a 14mm head bolt.
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
seeeya04
Suspension & Brakes
13
Jan 15, 2005 11:39 AM
neilff
May 30, 2003 12:03 PM
