nippon piston ring set has 3 bronze oil seals and one black one?
did i get a defective set or is this normal and can anyone tell me if this is normal if it makes a difference witch piston the odd colored oil ring goes on
these are going in an ls block with pr3 pistons btw
Modified by si0385. at 1:06 PM 5/14/2006
Its like when you buy a hardware kit for a skateboard, most companys give you one in a diff color (for luck)
Its the lucky oil ring man.
Really tho Idk If its the same size i would worry, they probley just ran out of the silver one or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACE »</TD></TR><TR><TD CLASS="quote">Its like when you buy a hardware kit for a skateboard, most companys give you one in a diff color (for luck)
they dont give you an extra screw for "luck" its to put on the front of back of your skate.
</TD></TR></TABLE>they dont give you an extra screw for "luck" its to put on the front of back of your skate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al_9000 »</TD></TR><TR><TD CLASS="quote">they dont give you an extra screw for "luck" its to put on the front of back of your skate.</TD></TR></TABLE>
Always seemed lucky to me.
275Performance
Jan 2, 2003 04:51 PM
