Dizzy freanknstien, D serise into a B Series
Old May 14, 2006 | 11:21 AM
Metal Head's Avatar
Default Dizzy freanknstien, D serise into a B Series
B18A1, My dizzy is screwed, and im low on cash, however, I have 3 D serise Dizzies sitting around, anyone herd or actually taken the guts out of the D serise Dizzy and put them into the B serise Dizzy?
Im geting a code for TDC, which is one of the sensors in the Dizzy.
Also see wanted to buy, I need a new dizzy if I cant swap out internals from sohc to doch
Old May 14, 2006 | 11:29 AM
fmrprojects's Avatar
Default Re: Dizzy freanknstien, D serise into a B Series (slayerknot)
i know the ignitor and the coil is interchangable but iono bout the tdc sensor. just try it and let us know
Old May 14, 2006 | 11:34 AM
Metal Head's Avatar
Default Re: Dizzy freanknstien, D serise into a B Series (fmrprojects)
Well, I did actually, I took everything out, the whole shaft all sensors,
they all looks the same, bolted the same.
Although when we put it in, we got no codes, but it didnt work, it sounded like the starter was firing backwards.
Old May 14, 2006 | 11:44 AM
make sure the sensor on the shaft is not touching the magnet. and put some electrical grease on the connections
Old May 14, 2006 | 11:49 AM
Metal Head's Avatar
i wonder if non vtec and vtec has anything to do with it? I have a NON vtec B18A1 and I used a NON Vtec sohc d15b7 dizzy.
Old May 14, 2006 | 11:51 AM
i dont think it is a problem cause i used a dx into a LS
Old May 14, 2006 | 11:52 AM
sohcam01's Avatar
From: bay area, california, united states of america
bump
Old May 14, 2006 | 11:56 AM
Metal Head's Avatar
Default Re: Dizzy freanknstien, D serise into a B Series (sohcam01)
eh, to me it is, Like I said, I did it and it fire backward. YES EVERYTHING was installed correctl and the same as i took it out.
Old May 14, 2006 | 08:20 PM
JeffBro's Avatar
Maybe the plug wires are just wrong? Timming?
Old May 16, 2006 | 02:36 PM
Metal Head's Avatar
Default Re: Dizzy freanknstien, D serise into a B Series (JeffBro)
ok guys, mods may need to stickie this, here is the solution and what i figured out...
I have a B serise, I used the B serise Dizzy housing AND have to use the SHAFT as well, only thing swapable was the electronics in the dizzy. I used the SOHC d series ELECTRONICS, CANNOT USE its shaft, have to use the same shaft that is in the Dizzy from factory.
raverx3m
May 21, 2012 01:22 AM
hic pudgy
Dec 22, 2009 07:27 AM
lilsicsoul
Jan 22, 2009 09:39 PM
Metal Head
May 14, 2006 12:06 PM
DEVIN22CBR
Jul 16, 2003 01:51 PM
