Is this Radiator Single or Dual Core?
Old May 14, 2006 | 04:13 AM
Propulsion's Avatar
Default Is this Radiator Single or Dual Core?
I asked this in Tech, but didn't get a straight answer.
This came on my DX but Im not sure if the previous owner replaced it (he had a ls swap)
Enough cooling if I go H22?
Old May 14, 2006 | 12:28 PM
JasonST's Avatar
Default Re: Is this Radiator Single or Dual Core? (Propulsion)
From the looks of it, it does look like a dual core because it's thicker and shorter in length than the single cores i've seen, even if it's not I know of plenty of people who have done fine with single cores from their civic in h22 swaps. U should be ok eather way.
Old May 15, 2006 | 11:49 AM
fabworxs's Avatar
Default Re: Is this Radiator Single or Dual Core? (JasonST)
Well, its a single core but it is the BIG 92-00 Civic radiator not the small one.
Old May 15, 2006 | 01:40 PM
Propulsion's Avatar
Default Re: Is this Radiator Single or Dual Core? (fabworxs)
you sure about that? When I look through the cap, I see 2 rows of oval holes.
Old May 15, 2006 | 02:02 PM
fabworxs's Avatar
really...I thought the BIG Civic radiator just had wider tubes not actually dual core...if you see a second row of tubes then totally my bad...you'd be right...
Looney Llama
Jun 1, 2012 09:09 PM
pcguy760
Jul 9, 2006 11:56 PM
Propulsion
May 15, 2006 02:43 PM
nmudrumline
Sep 20, 2005 03:15 PM
ketchup
14
Aug 11, 2004 09:48 PM
