which axels seriously
Old May 13, 2006 | 09:05 PM
C1CRX's Avatar
Traffic signal tech
Default which axels seriously
ok i have heard a lot of different things when it comes to axels for a b-series swap into an EF chassis im gathering parts for a GSR into my 91 CRX SI the tranny will be cable but i wont know which one yet so can u please give me a conclusive answer for which axels i would need..
Old May 13, 2006 | 09:16 PM
EF_generation's Avatar
Default Re: which axels seriously (lvcrx)
I took my axles into work and compared them to all bseries motors I could think of and I found that only 90 thru 93 integ axles looked exactly alike I have a b16 outa a crx into a rex but all bseries trannies are interchange able so if you have an intermidiate shaft they should need the same ones
Old May 13, 2006 | 09:20 PM
C1CRX's Avatar
Traffic signal tech
Default Re: which axels seriously (el_payaso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el_payaso &raquo;</TD></TR><TR><TD CLASS="quote"> I took my axles into work and compared them to all bseries motors I could think of and I found that only 90 thru 93 integ axles looked exactly alike I have a b16 outa a crx into a rex but all bseries trannies are interchange able so if you have an intermidiate shaft they should need the same ones</TD></TR></TABLE>
i didnt understand pretty much anything u said LOL any other suggestions
Old May 13, 2006 | 09:25 PM
doublethink's Avatar
90-91 teg
Old May 13, 2006 | 09:26 PM
crxnj's Avatar
simply...all b-series axles will work on the passenger side..for the driver side you need to match the axle with the haflshaft....so if you're using the 94+ gsr swap then get som 94-01 integra axles...just have to remember to remove the dust rings from inside the hub...
Old May 13, 2006 | 09:28 PM
C1CRX's Avatar
Traffic signal tech
Default Re: which axels seriously (Mr.speaker)
thanx a lot for all your help so if i get some 94+ integra axles i should be fine and they should fit like stock right no changing anything else besides that dust ring
Old May 13, 2006 | 09:31 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">thanx a lot for all your help so if i get some 94+ integra axles i should be fine and they should fit like stock right no changing anything else besides that dust ring</TD></TR></TABLE>
yes..and it doesnt matter if the axles are abs are not,,alot of people say the abs axles bind but they're full of ****..
just so you know 99-00civicsi,94-01 integra,del sol b16a3 axles will all work..
dust ring removal
Old May 13, 2006 | 09:44 PM
C1CRX's Avatar
Traffic signal tech
and it wont make the wheels be in an akward position or anything?
Old May 13, 2006 | 09:51 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">yes..and it doesnt matter if the axles are abs are not,,alot of people say the abs axles bind but they're full of ****..
dust ring removal
Also, make sure the axle seal in the trans matches with the axles you decide to use. I tried using 94+ axles on the passenger side of my 93 gsr trans in my CRX. The axle wouldnt quite seal up against the trans and so it would leak a bit. Swapped it out to a 90-93 integra axle, and all was well
Old May 13, 2006 | 09:53 PM
crxnj's Avatar
Default Re: (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">and it wont make the wheels be in an akward position or anything?</TD></TR></TABLE>
never on any of my cars..or any cars ive swapped..
if the wheels sit in an akward postition you have other problems,,alignment or possibly bent suspension components..
user 72830283
Aug 25, 2005 08:54 AM
chingro
Apr 22, 2005 10:22 PM
granturismonut
Mar 30, 2004 06:02 PM
Charlie Moua
Aug 8, 2002 06:12 PM
