gsr swap
Old May 13, 2006 | 08:20 PM
1990jdmgsrhatch's Avatar
New User
Default gsr swap
I recently purchased a 94 gsr to put into my 90 si. At first I switched out the hydro tranny to a cable (a lot easier). But now I want to put the hydro back in. I already have the mount kit from innovative mounts and I have figured out how it works. My next problem is getting the speedometer to work because the cable tranny reads the speed differently. Is this an easy fix? Does anyone out there know how to wire in the hydro tranny speedo? As far as I know Vtec will not work without the speedometer working for OBD1. Any help will be greatly appreciated!!!!!
Old May 13, 2006 | 09:27 PM
doublethink's Avatar
Default Re: gsr swap (1990jdmgsrhatch)
aftermarket speedo, or a jdm cluster, or an ek cluster has electronic speedo.
Old May 13, 2006 | 09:29 PM
crxnj's Avatar
Default Re: gsr swap (doublethink)
remove the electric vss from the hydro tranny and replace with the one you have in the cable tranny right now,, speedo gear and all..
Old May 13, 2006 | 10:30 PM
highflyinhonda's Avatar
does switching the vss from the stock d series in the si into a hydro trannt actually work? i thought that the speed sensors are different from b to d series trannies.
Old May 14, 2006 | 12:40 AM
Broke EF's Avatar
nope, it works. Dont ask how I know
Sean
Old May 14, 2006 | 12:44 AM
Arvid's Avatar
Default Re: (highflyinhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highflyinhonda &raquo;</TD></TR><TR><TD CLASS="quote">does switching the vss from the stock d series in the si into a hydro trannt actually work? i thought that the speed sensors are different from b to d series trannies.</TD></TR></TABLE>
Yes, this works great. I did this myself when I swapped in my OBD1 GSR with ITR tranny. The D series unit bolts perfectly onto the B series transmission.
Old May 14, 2006 | 04:15 PM
New User
thank you guys...this helps out a lot...is it easy switching the speedo? I have never messed with trannys before. Do I need to crack the case open, or will it come out without cracking it open?
Thanks again for the help!!!!
Old May 14, 2006 | 10:52 PM
Arvid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990jdmgsrhatch &raquo;</TD></TR><TR><TD CLASS="quote">thank you guys...this helps out a lot...is it easy switching the speedo? I have never messed with trannys before. Do I need to crack the case open, or will it come out without cracking it open?
Thanks again for the help!!!!</TD></TR></TABLE>
You just remove the bolt(s) holding it down and then pull it straight up. Kinda tight fit to do this if the engine/tranny is in the car.
Old May 14, 2006 | 11:54 PM
crxnj's Avatar
Default Re: gsr swap (Arvid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arvid &raquo;</TD></TR><TR><TD CLASS="quote">
yeah,,and its probably not just going to come out like butter..so just keep playing with it and pulling
RACEPAK
Nov 9, 2023 07:24 AM
spunautosports
Oct 26, 2006 11:26 AM
MANDO6669
Jun 7, 2006 09:19 PM
wickedEFguy
Dec 16, 2002 03:51 PM
