How to: Install SRR rear LCA's (lots o pix, hella not 56k)
Old May 13, 2006 | 07:20 PM
IGGY's Avatar
Default How to: Install SRR rear LCA's (lots o pix, hella not 56k)
Tools needed:
19mm long socket
14mm long socket
Jack Stands
Jack
Torque wrench
Air impact gun (Optional, use a wratchet if you don't have one)
Steps:
1. Raise the rear of the car and place it on jack stands:
2. Remove the wheels:
3. Remove the 3, 14mm bolts on the LCA from the center of the car toward the brakes:
4. Instal new LCA in reverse order of 3. DO NOT TORQUETHE BOLTS:
1.
2.
3.
5. Using the jack load the suspension by lifting the car from the rotor. Lift until the car comes up off the jack stand slightly:
6. Torque the 3 LCA bolts to 40 foot pounds:
7. Unload the suspension and put the wheel back on the car.
8. Repeat the steps 3-7 for the other side.
9. Lower the car back on the ground:
10. Torque the lugnuts.
That's all!
Some notes
The weight of the SRR LCA's is 2lbs vs. 4lbs for GSR LCA's
Side by side compairison:
Old May 13, 2006 | 07:29 PM
ekcivic9's Avatar
very nice how to
did you notice a change in the suspension?
Old May 13, 2006 | 07:32 PM
Banned HT Member's Avatar
Default Re: (ekcivic9)
Awesome diy
Old May 13, 2006 | 07:45 PM
IGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">very nice how to
did you notice a change in the suspension?</TD></TR></TABLE>
I just did it. Like maybe 45min before I posted, so havn't noticed anything yet.
Old May 13, 2006 | 07:48 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (IGGY)
nice pictures too man..
great write up
Old May 13, 2006 | 07:54 PM
crazi_E's Avatar
Default Re: (IGGY)
i will be using this myself..nice and simple..
Old May 13, 2006 | 08:13 PM
broketuner-Sol_Si's Avatar
Default Re: (crazi_E)
very nice write up. Didn't know there was a specific order to the LCA bolts.
Old May 14, 2006 | 12:12 AM
thahuhstunna's Avatar
Default Re: How to: Install SRR rear LCA's (IGGY)
fine post and great pics... well done
Old May 14, 2006 | 01:03 AM
midwesta's Avatar
are those even "bushings" in the SRR LCA? or are they just metal?
Old May 14, 2006 | 01:15 AM
Default Re: (midwesta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midwesta &raquo;</TD></TR><TR><TD CLASS="quote">are those even "bushings" in the SRR LCA? or are they just metal?</TD></TR></TABLE>
Yes almost any material can be a bushing, anything from a pvc pipe to a cnc machined aluminum piece.
Old May 14, 2006 | 03:14 AM
BlueIntegraBoy's Avatar
Default Re: (broketuner-egb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">very nice write up. Didn't know there was a specific order to the LCA bolts. </TD></TR></TABLE>
No not really. I went from outside to inside.
Old May 14, 2006 | 03:51 AM
jdm_bones's Avatar
Default Re: (BlueIntegraBoy)
Props! Very good write up, are you by any chance a Laker fan ...purple and yellow combo...Cool..
Old May 14, 2006 | 07:27 AM
mikeg015's Avatar
Where did you order them from?
Old May 14, 2006 | 10:43 AM
IGGY's Avatar
The bushings are sphercial which means there is no rubber. It is a metal ball in a metal cup so it pivots. They are sealed so dirt doesn't enter the cup and wear out the bushing.
The is the order I chose for ease of removal and installation. The rear trailing arm usually hangs the 2 bolts toward the middle are harder to get out. If you work them out from the outside in, the LCA just falls as you go.
Old May 14, 2006 | 11:13 AM
blackstar's Avatar
war all of the time......
Default Re: (IGGY)
how much were those spherical bearings?
Old May 14, 2006 | 12:40 PM
Falqon's Avatar
Default Re: (blackstar)
talk about massive overkill tools, wow.
Old May 15, 2006 | 10:29 AM
IGGY's Avatar
I got them from KIWI.
Check this thread if your interested in buying them:
https://honda-tech.com/zerothread?id=1613159
Blacknight117
Suspension & Brakes
Jul 14, 2012 03:14 AM
Civicpmp04
28
Jan 31, 2006 08:27 AM
Shake and Bake
26
Jan 14, 2006 11:57 PM
Calsonic180
Feb 21, 2004 08:31 PM
Ragezero76
14
Oct 12, 2002 05:36 PM
