Ignition switch harness.
Old May 13, 2006 | 03:36 PM
Marlon88's Avatar
Default Ignition switch harness.
Hello
Today I went to a shop and I got a turbo timer from them , they offerd to do the installation .
The guy made a mistake and cut a wire my mistake and he messed up my ignition wire harness ( the wires that goes from the ignition key switch to the fuse box )
Can the ignition key harness be replaced without changing the key switch ?!
I can go to this guy who import Japan parts and I can take off a complete switch with harness from an other ITR but I only want to change only the wires part not the whole thing ! is it possible?
Thanks in advance,
Marlon
Old May 13, 2006 | 06:01 PM
KayOs's Avatar
Default Re: Ignition switch harness. (Marlon88)
I would have the shop worry about how to fix your problem.
Old May 13, 2006 | 10:20 PM
Chris F's Avatar
You don't need a new ignition switch. All the wires can be repaired or replaced.
Old May 14, 2006 | 05:29 AM
Marlon88's Avatar
Default Re: Ignition switch harness. (Chris F)
Thanks for the replys guys
On the back of the switch there are 2 screws holding the back cover where the wires are solderd but I was affraid taking them out because I don`t want something to pop out and brake the switch !
Has anyone here opend a switch before and can give me some info.
Thanks
Marlon
danmdevries
May 6, 2012 10:38 AM
Ktribb87
Apr 24, 2011 12:48 PM
InfamousRS
Jan 22, 2006 10:39 AM
kHoA DoGG
Sep 9, 2003 01:00 PM
