what the best way to put a mark for timming on a aftermarket flywheel??????
any info will help ,,,im figuring get everything tdc then mark bettwen the pointer at tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">scribe it and whiteout?</TD></TR></TABLE>
i know that,,,,,,,,,
im wondering how to get this to be rite on the money
Are you asking how to find TDC?I've used a piece of welding rod screwed into the indicator through the spark plug hole on cyl. #1.
please only reply if you have done this!!
trace it the flywheel with paper, mark the locations, line it up on the new flywheel, and put the marks accordingly, prolly use some stiff paper so it doesnt move much and mark a center
something like that
he needs to do it on the flywheel because on h-series motors u check timing at the flywheel, not on the crank pulley
and i do believe he has a h22 motor
something like that
yesir thanx very much the only thing is the tarnny is already in the car so imn pretty much thinking get everything TDC then mark inbetween the pointer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">i know that,,,,,,,,,
im wondering how to get this to be rite on the money </TD></TR></TABLE>
A piston stop and a degree wheel should do nicely.
lilo_goki
24
Mar 18, 2008 06:37 PM
pentaq
Apr 29, 2003 04:36 AM
