jdm gsr swap...and all a sudden no reverse
Old May 13, 2006 | 12:07 PM
atmosphere's Avatar
Default jdm gsr swap...and all a sudden no reverse
just did jdm gsr swap...from the begining it was a little hard to get into reverse. one morning i try to back out of the garage and just cant get it in the gear at all. shop looked at it. everythings hooked up fine. its inside the tranny. any ideas guys?
Old May 13, 2006 | 12:51 PM
SiYouLater's Avatar
Default Re: jdm gsr swap...and all a sudden no reverse (atmosphere)
The synchros are probably gone.
Old May 13, 2006 | 01:13 PM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi &raquo;</TD></TR><TR><TD CLASS="quote">The synchros are probably gone.</TD></TR></TABLE>
agree
Old May 13, 2006 | 01:22 PM
95DX_D15B's Avatar
Default Re: jdm gsr swap...and all a sudden no reverse (e gee two)
I will also agree. i know my synchros are doing in my tranny(its not a gsr) but i usually have to push the clutch in 2 or 3 times before it will go in.
Old May 13, 2006 | 01:27 PM
Soccerking3000's Avatar
Default Re: jdm gsr swap...and all a sudden no reverse (95DX_D15B)
i thought reverse doesnt have syncro's? anywho the reverse is a straight cut gear try letting the clutch out really slowly while trying to put it in reverse, thats what i have to do so the gears line up
Old May 13, 2006 | 01:33 PM
B20luda's Avatar
There is no reverse synchro
Old May 13, 2006 | 02:15 PM
ReDHaTcHyGuy's Avatar
Default Re: jdm gsr swap...and all a sudden no reverse (B20luda)
what shift linkage did u use??? does it go into reverse when the car is not running
Old May 13, 2006 | 02:27 PM
JDM-97CX's Avatar
Default Re: jdm gsr swap...and all a sudden no reverse (99FBPSi)
Shut up. You don't know anything about transmissions at all. You don't even know what a synchro is, or what it even looks like.
Reverse is NOT a synchronized gear because you do not enter it while moving.
Old May 13, 2006 | 02:35 PM
aZnjCC's Avatar
it didn't even want to go in after putting it in a forward gear first?
Old May 13, 2006 | 02:38 PM
JDM-97CX's Avatar
Default Re: (aZnjCC)
Well, I'm going to go out on a limb here and say that you probably aren't comfortable with tearing into a trans and don't have the right tools either. If I was you, I would take the car into the dealership (not as expensive as everyone thinks and they have FACTORY TRAINED and CERTIFIED techs) and have them take a look at it.
Old May 13, 2006 | 04:18 PM
atmosphere's Avatar
everythings hooked up fine...i duno about going to the dealer....thats gonna be pricy because they are gonna have to open up the tranny....if its not the synchros wat would you guys say it is?
ek9800
Nov 6, 2007 09:41 PM
modulo_s
Honda Motorcycles
14
Jun 6, 2007 02:16 PM
z51LS2
Apr 16, 2006 05:17 PM
shorty0o29
Apr 30, 2003 08:45 PM
io_burn
Apr 25, 2003 07:13 PM
