CEL after tranny swap? trying to get ECU code?? no connector???
Old May 13, 2006 | 11:35 AM
shanepa2001's Avatar
Default CEL after tranny swap? trying to get ECU code?? no connector???
ok i have a 93 civic CX with D15b vtec and smallbox p08 ecu. i just put a new tranny in and now my CEL is on. all connectors in and everything and i dont know why CEL light is on. now i searched for a way to rig CEL light blinking to determine code and found this..
https://honda-tech.com/zerothread?id=1446321
for some reason i cant find the gray connector ANYWHERE at all with the two wires in it. now i do have 2 connectors, both blue and look fairly new, hanging next to my ECU. connector # 1 has 3 wires (black with red stripe, white with red stripe, and one baby blue wire) connector # 2 has 2 wires (green with white line, other is brown wire)
the Question is now, how do i hook up to check the ECU code? any info would help i am tryin to go somewhere far and i dont like the CEL light on for a road trip wana fix whatever is wrong before i leave.
thank you
shane
Old May 13, 2006 | 11:53 AM
Default Re: CEL after tranny swap? trying to get ECU code?? no connector??? (shanepa2001)
ok
i jumped the ecu figured it out anyway and am getting a code 6 (coolant temp sensor what does that mean and how do i fix it
91efbluehatch
21
May 30, 2017 10:19 AM
radicaled434
Aug 16, 2012 07:02 AM
crvtt96
Jun 6, 2004 04:00 PM
Toda Built
Jul 10, 2003 02:46 AM
bossman032
May 18, 2003 08:55 PM
