Dx chaged to MPFI, Trouble codes 4 CKP and 7 TPS, help me diagnos and tune
Old May 13, 2006 | 11:24 AM
JustWant1GoodCar's Avatar
Default Dx chaged to MPFI, Trouble codes 4 CKP and 7 TPS, help me diagnos and tune
Ok. I just upgraded my dx civic to MPFI.
I used an ecu from an 89 integra (PG7) with an intake manifold from a 96 civic and the same distributor. All this on a SOHC zc block from japan. I also threw on an adjustable fuel pressure regulator. I have high hopes of horsepower gains. If you have any insight on tuning this setup I would appreciate it. My main questions are timing, fuel pressure setting and bolt-ons that will give me the most bang for my buck.
The problem that am now facing is that the check engine light is on and I have no manual or wiring diagrams to help me diagnose my CKP and TPS codes. I don't even know exactly where my CKP is. Im trying to find the location of the CKP and the best way to test it.
If you know where I can just get a good wiring diagram for my ecu I think that would be really helpful.
Thanks
Old May 13, 2006 | 02:31 PM
dr_latino999's Avatar
Default Re: Dx chaged to MPFI, Trouble codes 4 CKP and 7 TPS, help me diagnos and tune (JustWant1GoodCar)
So which distributor did you use exactly? Year / Model please
Old May 13, 2006 | 02:38 PM
ludesrv's Avatar
Crank sensor is in the dizzy on OBD0 cars. Looks like you will need to change your dizzy.
Old May 13, 2006 | 02:54 PM
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Crank sensor is in the dizzy on OBD0 cars. Looks like you will need to change your dizzy.</TD></TR></TABLE> Or check your wiring.
Old May 13, 2006 | 02:55 PM
This setup was installed on my friends car with no problems. The distributor is practically new. He told me it was the right one for the manifold which was from a 96 ex civic W/ a 1.6 vtech. The numbers on the side read:
TD-02U
M7220401A
0090-0029
This thing looks like it is brand new.
Is a Dizzy a distributor or something else?
Old May 13, 2006 | 02:57 PM
I also know I need to check my wiring, but I have no diagrams and I don't know how to test the components. Thanks
Efsdn89
Sep 27, 2018 08:34 PM
bigblu333
Jan 5, 2004 03:48 PM
moike
Oct 7, 2003 12:28 AM
the DR.
Jul 1, 2002 06:14 AM
CimorelliCRX
Apr 3, 2002 12:18 AM
