h22a vtec problems
Old May 13, 2006 | 10:49 AM
rigles1's Avatar
Default h22a vtec problems
so i have an h22a1 on an ek but for some reason vtec is not kicking in..
i tried doing as much research as i can by looking at old posts so here is what i checked..
oil is filled all the way up..
i cleaned filter on the solenoid..
i checked to see if solenoid works and it does..
i just recently tried seeing if there might be problems with the ecu... so here is where my other question comes in..
there are two sensors on the vtec solenoid right? the vtec pressure valve (green one) and vtec spool solenoid valve.. so i unplugged both of them and tried to see if it would throw a code.. and it did.. but only for the vtec pressure valve (code 22) and not the vtec spool solenoid valve (code 21)...
but my ecu should also be throwing a code for the vtec spool solenoid valve right (code 21)? cuz its not plugged in right?
so i am really confused about this.. could this be the problem with me not being able to hit vtec?
any suggestions? or experiences with this problem?
Modified by rigles1 at 12:01 PM 5/13/2006
Old May 13, 2006 | 12:10 PM
djsire's Avatar
Default Re: h22a vtec problems (rigles1)
is your tach and speedo working?
you car has to be warmed up
Old May 13, 2006 | 12:42 PM
rigles1's Avatar
Default Re: h22a vtec problems (djsire)
yes.. speedometer and tach work.. does that help engage vtec?
Old May 13, 2006 | 07:43 PM
jdm_h22power's Avatar
hey bro have u check your knock sensor yet cause the same thing happened to mine. help that helps
Old May 13, 2006 | 08:02 PM
rigles1's Avatar
Default Re: (jdm_h22power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_h22power &raquo;</TD></TR><TR><TD CLASS="quote">hey bro have u check your knock sensor yet cause the same thing happened to mine. help that helps</TD></TR></TABLE>
yeah.. i checked it.. and plus its not throwing a code wen i checked it on ecu..
but on original question.. since i unplugged both sensors from the vtec solenoid.. both sensors should be throwing a code right? the sensors i was talkin about was the vtec spool solenoid sensor (code 21) and vtec pressure valve (code22)...
keychild486
11
Apr 2, 2008 06:28 AM
Pr0ject93hb
Sep 14, 2007 09:50 AM
DohctorVtec
Jul 5, 2005 01:35 PM
