can anyone help newbie
I just bought a projet crx with no motor off ebay??......I was wondering if it is an hf...and would a b18c fit in this
http://cgi.ebay.com/ebaymotors...%3AIT
I cant tell if its an HF but I know for a fact that you can fit that b18c in there with some mounts and a few other parts. Looks like its gonna be a fun project. Make sure that its not damaged with rust or any major accident.
what other stuff would i need instead of motor mounts b/c this is my first projcet..sorry for asking an i know someones gonna say search
You'll need ;
Engine
Tranny
ECU
Wire Harness
Hasport Mounts
Hasport Axles
Shat , what else is missing ?
~~~ 1988 CRX Si ~~~
Thermal R&D Header Back Exhaust.
Header.
Teg. ECU.
CAI.
Tenzo RS-5 Wheels.
Bridgstone Potenza Tires.
Progressive springs.
Stainless Brake Lines.
Momo Wheel , **** , ect inside.
Short Shifter.
Audio by Eclipse & JL Audio.
Engine
Tranny
ECU
Wire Harness
Hasport Mounts
Hasport Axles
~~~ 1988 CRX Si ~~~
Header.
Teg. ECU.
CAI.
Tenzo RS-5 Wheels.
Short Shifter.
You do not need hasport axles. You can use some 90-93 integra axles. You also may not need a harness depending on what harness you have in your car. You will need a shift linkage, ECU, mounts of your choice ( several different companies ), cable tranny unless you want to convert to Hydro, and it may need a little rewiring depending on what harness you have and whether or not you want obd1 or 0.
Of course you have other brands to choose from that was off the top of my head.
I forgot about the old Teg. axles. You nailed the shift linkage............
Theres still somthing missing ?
alright thanks and I want to know what everyones opinon of this engine is
http://www.hmotorsonline.com/s...30009
Im getting the lsd tranny...
I think i'm going to throw up in my mouth over what the prev. owner did to that car. You gotta bring her back to life , Do you plan on repainting the car ?
If so nows the perfect time since that engine bay is empty.
What are your plan's ?
It would make one hell of a sleeper just to leave it as is and do your swap. lol
I probably will paint the car but further on down the road....right now its gonna be all go no show.....Ill prolly get a stock front bumber but thats it.....
