Acceleration shudder (searched)
Old May 13, 2006 | 09:58 AM
B16-CRX's Avatar
Default Acceleration shudder (searched)
Hey i have a strange acceleration prob in my b16 crx. When im going slow in 1st and 2nd gear it seems like the car is jerking forward and back. Almost like im feathering the thottle. I have new axle is the front. What could it be? Clutch? TPS. Thanks in advance.
Heres a pic of my work in progress. . . .
Old May 13, 2006 | 04:17 PM
B16-CRX's Avatar
come on. Any ideas
Old May 13, 2006 | 04:20 PM
CRXBart's Avatar
Default Re: (B16-CRX)
it probally has somthing to do with that window tint. Remove that crap and I bet the problem goes away.
Old May 13, 2006 | 04:22 PM
gospeedgo1's Avatar
Default Re: (CRXBart)
rack end bushing could be a possibility if the steering wheel shakes a little bit, ball joints, steering box
Old May 13, 2006 | 05:00 PM
143MYVTECEF's Avatar
Default Re: (gospeedgo1)
do you have a motor swap? i know i have a shuddering problem becasue the mounts im using are to stiff for my application. but i can live with it
Old May 13, 2006 | 09:35 PM
B16-CRX's Avatar
The tint is gay. Im taking it off when i get the spray remover.
Old May 14, 2006 | 04:46 AM
crxblues's Avatar
take a razor blade to it. take the yellow tint off while your at it too.
Old May 14, 2006 | 04:54 AM
si0385.'s Avatar
you guys are being a great help and all with his acceleration problem telling him how ugly his tint is...
my money goes towards clutch... did you put a new one in when you did the swap?
Old May 14, 2006 | 05:12 AM
D Rex's Avatar
Default Re: Acceleration shudder (B16-CRX)
Is this a new swap? JDM/USDM ? What axles did you use? What Ecu? What knuckles? Did you remove the dust ring from them? What did you use for the throttle cable bracket? Give as much info as you can and you'll get more help and less crap..
Old May 14, 2006 | 07:25 AM
B16-CRX's Avatar
Default Re: Acceleration shudder (D Rex)
Its a jdm b16a. I have 90-93 integ. axles and hubs. I have not checked the dust rings, but it doesn't seem to bind. I'll take a look today. I am assuming that the clutch is stock.
Old May 14, 2006 | 01:08 PM
What mounts did you use?
Old May 14, 2006 | 04:34 PM
JadeGreenEF9's Avatar
my car is doing the exact same thing. Say im coming to a light and its red so I slow down and down shift into second, light turns green so I go to push the gas and it stutters then goes. Does it in first too sometimes. I have to rev really high to take off or it will stutter
Old May 14, 2006 | 05:24 PM
racingcrx's Avatar
you have a rust spot ya kno. have you removed the thingy that causes it to rust?
nice crx btw
ohsnapzafingcu
May 11, 2006 05:13 AM
Bserieskiller
Suspension & Brakes
Feb 17, 2006 01:20 PM
GoobyEP3
Sep 24, 2005 10:57 PM
CCRX
Aug 28, 2005 03:31 PM
slowassR
Sep 24, 2002 12:48 PM
