Stereo Wont work when Inserted CD only
Old May 13, 2006 | 09:44 AM
Jose-aka-Pedro's Avatar
Default Stereo Wont work when Inserted CD only
Ok guys here is my problem,
My stereo didnt work and I couldnt figure it out, It was a fuse so I replaced it.
Now, I can use the radio, But when I insert a CD The stereo will turn off and on over and over.
It only does this when I have a CD in it.
Whats the problem?
Thanks, Later
Old May 13, 2006 | 01:08 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Check the ground, Also make sure you are getting 12 volts to the acc wire and battery wire on the radio, Theses wire should show atleast 14 volts while the car is running. It sounds like there is not enough voltage getting to your radio or a lack of ground.
I seen this happen on alot of mitsu mirage's because there is no ground wire and people think by plugging in the anttena is going to provide it when it plugged in. But from your avatar i see its a da. If all checks well it could be that your head unit is going out. gl
davey5300
Dec 11, 2008 10:33 PM
vandersmissenc
Apr 2, 2007 06:10 PM
ineedmoney
Audio / Security / Video
Jun 3, 2004 10:30 PM
redex94
Oct 8, 2003 01:13 PM
rad_thundercat
Aug 23, 2002 10:21 PM
