replacing front sub frame on coupe?
Old May 13, 2006 | 09:22 AM
skunkcoupe's Avatar
Default replacing front sub frame on coupe?
Alright well for some reason the long bolt holding the front LCA's on through the sub frame are def stripped out. I think there is a welded on nut that you cant see or get to, but it might have broken off! Anyway basically i need to replace the sub frame! Is it possible? and if so how hard because i dont have the best of tools or work environment so! any help appreciated thanks!
Old May 13, 2006 | 10:16 AM
skunkcoupe's Avatar
Default Re: replacing front sub frame on coupe? (skunkcoupe)
bump for some help!
Old May 13, 2006 | 10:22 AM
EH339's Avatar
I just had the sub-frame to my Si replaced. I think that it wasn't too difficult, but having a lift is really helpful to the project. Otherwise, my car feel great now. The u-joint in the steering column of my old setup was really tired and loose.
Old May 13, 2006 | 10:24 AM
skunkcoupe's Avatar
Default Re: replacing front sub frame on coupe? (EH339)
what was the cost to have it replaced?
Old May 13, 2006 | 10:28 AM
Luserkid's Avatar
If the motors in the car ill give it a 7 out of 10 if the motors out of the car ill give it a 6 out of 10. Its not hard as much as time consuming and having to break really hard bolts loose.
Why not cut a grove under the nut and replace it? Much easier then replacing the subframe.
Old May 13, 2006 | 10:31 AM
skunkcoupe's Avatar
Default Re: replacing front sub frame on coupe? (Luserkid)
actually i think im gonna try that! that wouldnt weakin the subframe or anything like that?
Old May 13, 2006 | 10:34 AM
EH339's Avatar
A tech at the dealership did it for me afterhours... I paid him $150 which included an alignment.
Old May 13, 2006 | 10:37 AM
skunkcoupe's Avatar
right on! thanks
lolv8s
Suspension & Brakes
Jul 16, 2013 12:40 PM
brookliner7
Jun 5, 2012 02:47 PM
the_big_dl86
May 6, 2009 09:58 PM
Luckywhiteboi
Feb 28, 2009 10:24 PM
shyboy817
Audio / Security / Video
Dec 2, 2004 05:43 PM
