replacing front sub frame on coupe?
Alright well for some reason the long bolt holding the front LCA's on through the sub frame are def stripped out. I think there is a welded on nut that you cant see or get to, but it might have broken off! Anyway basically i need to replace the sub frame! Is it possible? and if so how hard because i dont have the best of tools or work environment so! any help appreciated thanks!
Re: replacing front sub frame on coupe? (skunkcoupe)
I just had the sub-frame to my Si replaced. I think that it wasn't too difficult, but having a lift is really helpful to the project. Otherwise, my car feel great now. The u-joint in the steering column of my old setup was really tired and loose.
If the motors in the car ill give it a 7 out of 10 if the motors out of the car ill give it a 6 out of 10. Its not hard as much as time consuming and having to break really hard bolts loose.
Why not cut a grove under the nut and replace it? Much easier then replacing the subframe.
brookliner7
06-05-2012 02:47 PM
the_big_dl86
05-06-2009 09:58 PM
shyboy817
Audio / Security / Video
12-02-2004 05:43 PM
