camber kit??
Old May 13, 2006 | 07:28 AM
$racer1's Avatar
Default camber kit??
I need a camber kit 4 my car,just don't know what to get? I had a brand new set of tires and 1 week later there no good from the inside of the tire. my wheels sit butterflyed in.need help what to get.
Old May 13, 2006 | 07:47 AM
Targa250R's Avatar
be professional
Default Re: camber kit?? ($racer1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $racer1 &raquo;</TD></TR><TR><TD CLASS="quote">I need a camber kit 4 my car,just don't know what to get? I had a brand new set of tires and 1 week later there no good from the inside of the tire. my wheels sit butterflyed in.need help what to get.</TD></TR></TABLE>
You don't need a camber kit, you need a toe alignment.
A few degrees of negative camber won't wear out a brand new set of tires in a week.
Old May 23, 2006 | 07:57 PM
$racer1's Avatar
Default Re: camber kit?? (Targa250R)
well i took my car to the tire shop, i guess you were right my toe aligment was off by 4 degresse, the most he could do was 2 degress, so its still of by 2. Its rides better but still need to fix it. My camber was all the way ajusted. What else do u suggest??? THanks Bro
Old May 23, 2006 | 08:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $racer1 &raquo;</TD></TR><TR><TD CLASS="quote">the most he could do was 2 degress</TD></TR></TABLE>
Why? Did he explain a reason?
Old May 23, 2006 | 08:23 PM
supracrx's Avatar
yea is the toe adjustment maxed out? may need new tie rod ends...? when i got an alignment after i lowered it i have 2 degrees of camber but my toe was rite in spec..got it adjusted perfectly for the front and rears.
Old May 26, 2006 | 04:08 AM
$racer1's Avatar
Default Re: (supracrx)
don't know what else i need, he said i need a better camber kit..?? Don't know what kind is on there right now. I will post pics
Old May 26, 2006 | 07:01 AM
user 98292739's Avatar
ummm he should of still been able to set your toe. i am dropped 4 inches with a 2 way adjustable camber kit( 1 1/2 inches or 3 inches) of course its on 3 right now. my toe is almost perfect my camber is .2 to .8 degrees off.
Old May 26, 2006 | 07:08 AM
temp's Avatar
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">ummm he should of still been able to set your toe. i am dropped 4 inches with a 2 way adjustable camber kit( 1 1/2 inches or 3 inches) of course its on 3 right now. my toe is almost perfect my camber is .2 to .8 degrees off.</TD></TR></TABLE>
being dropped that low is not helping you at all
Old May 26, 2006 | 07:26 PM
helping me with what? im not an auto crosser, nor a drag racer, or even a street racer. im doing it soley for looks.
sublimeh215
Suspension & Brakes
Feb 10, 2009 07:34 PM
zach1288
42
Nov 18, 2007 06:12 PM
asergioc
Sep 7, 2007 03:42 PM
B18C5er
Suspension & Brakes
20
Nov 18, 2005 07:44 AM
CivicSwapper
Dec 11, 2003 06:53 AM
