Replaced vtec selonoid gasket and still leaking...
Old May 13, 2006 | 05:25 AM
divingcorners's Avatar
Default Replaced vtec selonoid gasket and still leaking...
anyone have any ideas as to why?
thanks
Old May 13, 2006 | 05:33 AM
RACEPAK's Avatar
Default Re: Replaced vtec selonoid gasket and still leaking... (divingcorners)
maby its got a ding somewhere on the flange?
try to tight it a bit more.
Old May 13, 2006 | 07:58 AM
1bar_ek's Avatar
Maybe the leak isn't coming from your vtec selonoid gasket. Try checking the cam plug, oem ones usually leak.
Old May 13, 2006 | 08:00 AM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar_ek &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the leak isn't coming from your vtec selonoid gasket. Try checking the cam plug, oem ones usually leak.</TD></TR></TABLE>
yes check your cam seal if not go ahead and change your dizzy o ring.
3 things known to go bad on honda motors and cause leaks:
dizzy o ring
vtec selonoid
cam seal
good luck
ramboPandA
Mar 1, 2017 02:58 PM
98_ssbp
Oct 11, 2012 10:45 AM
yoffer
Aug 21, 2012 03:23 PM
kc_kc
Dec 23, 2010 07:58 AM
SLIMJIMsi97
Mar 24, 2002 04:19 AM
