95 accord lx auto speed sencor?????????????
Old May 13, 2006 | 04:46 AM
lc4132's Avatar
Default 95 accord lx auto speed sencor?????????????
What does the speed sencor acualy do and how do I know it it needs to be replaced
Old May 13, 2006 | 05:34 AM
S CARTER's Avatar
Default Re: 95 accord lx auto speed sencor????????????? (lc4132)
This is how the sensor works..
With the ignition switch in ON (II) or START (III),
battery voltage is supplied through fuse 1 and the
YEL wire to the vehicle speed sensor (VSS). The
sensor is grounded by the BLK wire to G101. The
speedometer and other control units in the circuit
supply 5 volts or more to the ORN wire. The vehicle
speed sensor (VSS) intermittently grounds the ORN
wire which generates a pulsed signal in it. The
number of pulses per minute increases/decreases
with the speed of the car.
As for when to replace it when its broken
like when your speedometer goes out.
Old May 13, 2006 | 10:31 AM
raceACCORDingly's Avatar
doesnt "speed" sensor give you a clue?
its on the top back side of the tranny. auto and manual vss are the same, pull one from a junkyard. most likely the 90-97 vss are the same.
LaEzEnT
Dec 15, 2008 07:50 PM
rnbguy
Oct 25, 2008 10:36 AM
Turbowa
Feb 22, 2005 06:37 PM
rschoener
May 16, 2002 07:32 AM
