D15B Swap Air Fuel Mixture Problems
Old May 13, 2006 | 04:04 AM
Defile's Avatar
Default D15B Swap Air Fuel Mixture Problems
Here's the deal, I swapped a JDM D15B into my DX. I have a socketed P28 ECU, and 5 aftermarket chips, plus one custom made for the D15b's off the D15B's basemap.
The problem is, I had one tank that i actually got 17 mpg, thats really really low, also other evidence of a rich A/F mixture is i am getting carbon deposits on my rear bumper. Mind you ive had this exhaust for about 3-4 yrs, with no carbon deposits on the stock D15b7 engine. Also with any of the 6 chips, i'm idleing at about 900 rpms, with the stock setup it will idle at about 500-600 rpms..
Any thoughts on what could be causing the bad A/F mixture?
Old May 13, 2006 | 04:54 AM
project 2two9's Avatar
Default Re: D15B Swap Air Fuel Mixture Problems (Defile)
try adjusting your throttle... it might be to closed for all the chips you have set in the computer
JDMb18c1HATCH
62
Jul 24, 2010 07:05 AM
90jdmcrxdude
May 5, 2006 10:20 PM
JDM_SOHC
Apr 29, 2005 11:15 AM
SiR_Redneck
Sep 27, 2004 09:01 PM
