any of yall have problems with the new gas??
Old May 13, 2006 | 03:41 AM
skata89's Avatar
Default any of yall have problems with the new gas??
its seems when i filled my car up the ota day it was having a hard time idling. anyone else having this problem?
Old May 13, 2006 | 03:45 AM
Micha's Avatar
FAILWGN
Default Re: any of yall have problems with the new gas?? (skata89)
Its your car getting used to not using gas. Its using corn.
Old May 13, 2006 | 03:54 AM
tomlinson619's Avatar
Default Re: any of yall have problems with the new gas?? (Blu99teg)
did u fill it up with soap
Old May 13, 2006 | 06:05 AM
roy.jovero's Avatar
Sounds like he used E85. Honda doesn't make any "Flex-Fuel" engines, so I don't know if you may have done more damage than good, all just because E85 is cheaper than gas.
Old May 13, 2006 | 06:23 AM
Dogginator's Avatar
Daisy... Daisy...
When they first introduced MTBE into gasoline, I noticed that my GSR and other vehicles with higher compression had a burning plastic smell from the exhaust. These EPA mandated additives are a band-aid to address the 1% of vehicles on the road that emit 90% of the air pollution. For well designed vehicles with good emissions systems, these additives simply rob power and lower fuel efficiency.
Old May 14, 2006 | 08:36 AM
skata89's Avatar
well i had too fill up with this new gas bc theyve converted every gas station around here to that. i filled it up with premium so i wasnt goin for the cheapest gas lol. how do you mean i could have done some damage? and what kinda damage could i have caused by using this new ethanol ****?
Old May 14, 2006 | 10:45 AM
sik96teg's Avatar
Default Re: (skata89)
i used it once when i was runin on fumes and thats all the gas station i pulled up to had i only put 5 bucks in just enough to make it to base where they have higher octane gas and lower prices. But it felt strong and wasnt eating thru the gas.
Old May 14, 2006 | 11:57 AM
Uncle Willie's Avatar
Theres no way they converted EVERY pump to 85%ethanol. Only a select few "Flex fuel" fords and gm automobiles came with the compatability to run that gas (could be more manufacturers but i am only aware of ford and gm). I def. wouldnt put it in my car...not made to run on that ****.
Old May 14, 2006 | 01:47 PM
Padawan's Avatar
Darth ModerVader
Default Re: (RIP Indian Larry)
I think there's a misunderstanding in this thread. The original poster is not referring to filling the car with E85. He is talking about the newly formulated gasoline that has recently been phased into service in many areas (some were already using the ethanol blend), which uses a percentage of ethanol as a replacement for a former additive called MTBE.
In response to the original poster, I have not noticed any issues with my engine's operation or economy. It's possible that you received a bad tank of fuel, but I wouldn't be overly concerned.
Old May 14, 2006 | 01:57 PM
skata89's Avatar
ight. thans Padawan.
Propulsion
Feb 21, 2004 12:20 PM
E-Rok
Dec 26, 2003 12:55 PM
ggangtong81
Oct 12, 2003 06:23 PM
garrybloom
Apr 24, 2003 09:28 AM
SjCiViCHB
Feb 14, 2003 06:35 AM
