D15B2 (or B7) block into EK with Y8 head and ecu
Old May 12, 2006 | 11:43 PM
The Internet Tough Guy's Avatar
Default D15B2 (or B7) block into EK with Y8 head and ecu
so i was supposed to be getting a z6 block, but apparently someone really needed 120 bucks. i found a d15b2 (or b7 not sure yet) out of a 90 civic. putting the y8 head that i have on would put the C/R around 10.5. the stock y8 ecu couldn't handle that right? what would i need (fuel pressure reg,, cam gear, chip anything like that?)
and i've bypassed the knock and ckf sensors so i can put an obd1 block in, is obd0 any different and would the y8 stuff bolt to it?
Old May 13, 2006 | 03:46 AM
AJxr's Avatar
Default Re: D15B2 (or B7) block into EK with Y8 head and ecu (The Internet Tough Guy)
if its the stock engine from the 90 civic is the b2, if its the 4spd std civic is the b1.
the ecu will work fine.
Old May 13, 2006 | 10:36 AM
Default Re: D15B2 (AJxr)
ok, any differences between the b2, b1, and b7?
will all my y8 stuff (water pipe, alternator, etc etc) bolt up to it?
Old May 13, 2006 | 01:14 PM
Default Re: D15B2 (The Internet Tough Guy)
ok i just found out it is a B2 out of a 90 dx, anyone put a y8 head on that block before?
Old May 13, 2006 | 10:42 PM
bump for some answers, this is important
Old May 14, 2006 | 09:29 AM
up
Old May 14, 2006 | 09:52 AM
4potnick's Avatar
go see the 88-91 guys they do it all the time.
Old May 14, 2006 | 08:01 PM
Default Re: D15B2 (4potnick)
bump
Old Jan 21, 2014 | 06:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
You just bumped an 8 year old dead thread. Are you ******* kidding me? It's called a mini-me. LOOK IT UP.
Hatzboy11
May 13, 2015 05:12 AM
radster87
May 16, 2013 12:31 PM
mykoe817
Apr 30, 2010 08:43 AM
SOHC_MShue
Oct 13, 2003 07:28 PM
