D15B2 (or B7) block into EK with Y8 head and ecu
so i was supposed to be getting a z6 block, but apparently someone really needed 120 bucks. i found a d15b2 (or b7 not sure yet) out of a 90 civic. putting the y8 head that i have on would put the C/R around 10.5. the stock y8 ecu couldn't handle that right? what would i need (fuel pressure reg,, cam gear, chip anything like that?)
and i've bypassed the knock and ckf sensors so i can put an obd1 block in, is obd0 any different and would the y8 stuff bolt to it?
Re: D15B2 (or B7) block into EK with Y8 head and ecu (The Internet Tough Guy)
if its the stock engine from the 90 civic is the b2, if its the 4spd std civic is the b1.
the ecu will work fine.
SOHC_MShue
10-13-2003 07:28 PM
